20 Most Recent
HP Pavilion DV5234US Notebook Laptop Questions & Answers
I got an AMD turion x2 64 processor in my new notebook n after reading reviews comparison to core 2 duo i m really tensed!
You made a good choice. In the CPU arena right now, the difference between the two CPUs is a toss up. The slight advantages of one vs. the other in benchmark tests is nominal and actually artificial..
What happens with an AMD CPU is with the associated GPU onboard. And with a 64bit processor, the number of apps and games that take advantage of 64bit CPUs has always been limited but they are growing. This will only become more and more numerous.
The main architectural difference in the two was in how the two cpus communicated and the AMD was first to use a bus between the two cores and the Intel had to go to the onboard memory controller and back. That was in the first inception. Still, AMD has been far in advance of Intel and Intel has played catch up in tricks inside the cores and how the north and southbridge took advantage of the cores' architecture.
Needless to say, I'm an AMD power user and my gaming rig has an AMD dual core on an Asus/Nvidia board and an Nvidia PCIe 9800 GPU.
In the long run, all modern notebooks require you to own a pad cooler to use these in your lap or not, they all produce heat. So, just get a good one designed for your laptop so it snaps into place and will keep your rig nice and cool.
At a LAN Party you won't suffer from having a dual core AMD cpu, you'll hold your own and it will be an even playing field and the wins will go to the person with the fastest fingers... as it should be.
Sleep easy friend,
Worldvet
Error 107 (net::ERR_SSL_PROTOCOL_ERROR): Unknown error.
You are using a security protocol not compatible with the site's certificate. It depends on which browser you're using, but I have a few fixes in mind.
If you're using Internet Explorer: At the top go to Tools then Internet Options, then click on the tab that says Advanced. Scroll down through the list and you want to make sure that "Use SSL 3.0" is checked.
If you're using Firefox: At the top go to Tools, then Options. Then the tab that says Advanced. Click on the tab in the lower portion that says Encryption. Make sure "Use SSL 3.0" is selected.
If you're using Google Chrome: Uninstall and reinstall the newest version.
Cd stuck in my HP 17-e061nr laptop..the door tray opens and closes fine but the cd wont come out
That's a tough one. First, be prepared for the CD to be ruined. The process of getting it stuck or extracting it is likely to cause some significant scratches. If you can look into the drive and see the disc, try using some tweezers to work it out. Take your time - it's likely to be jammed up in there pretty good.
If you can't see the disc you may need to remove the drive and either attempt to disassemble it or just replace it altogether (the latter being my recommendation). If you look on the bottom of your laptop you should see a screw that is positioned on the centerline of the optical drive at what would be the back of the drive. It may even have a disc icon next to it. Power off, unplug it and remove the battery. Remove the screw then try pulling the optical drive straight out from the chassis. If you need leverage, use a paper clip to push the manual eject (behind the little hole in the front bezel of the drive) and use the drawer to -gently- pull on the drive. Replacement is just a matter of sliding the drive back in, seating it in the connector and replacing the screw.
If you opt to replace the drive you should be able to find compatible parts on eBay if you don't want to pay HP for an OEM part.
Spilt milk
No even if you did replace those few dios who to say that it will still work. It will cost you more money trying to fix this motherboard while you can replace it one time, and be finished with it. I would contact HP and order a replacement motherboard.
No audio out put found
Hello manding, to restore any area dealing with the sound on your Computer; the same location will apply. First, click on the "Start Button," in the (right pane) Control Panel, next in the category listings, select Hardware and Sound, open and choose "Manage Sound Devices." The Sound window will open; click the "Playback" button, there should be a Speakers Icon, highlight to open, look below to find the "Properties button, open the next window. There will be (4) four buttons "General, Level... first select the "General" button. Next, in the top of the window there will be a "Driver" button, click on that button, select to "Update Driver." You can go back and "Tour the other areas, Speaker Level etc..." If you have a "MIC" do the same for the Microphone as you have done for (Speakers). Note: "Apply and OK all changes, to take effect. "Restart the computer to finalize the changes." I hope this information is helpful, thank you for using FixYa." paul70f9
If you are using an email program, you don't have the protocol setup correctly. If you are trying with a web browser, you have another problem.
If you are using Google's Chromium. I don't know of a fix except to use another web browser and set it to Classic mode. Now Google's Chromium should work.
Some time suddenly my screan be come white,
Have the HP check the video card driver. having a plain white screen with no icons or wallpaper means there's something wrong with the video card driver or the hardware itself.
I need Sound driver HP
Sorry to said but there are no drivers for your notebook for Windows 7. I suggest you to download from
this link previous drivers and use these drivers at your notebook in compatibility mode. This means that before the drivers installation, right click on the installation file, choose properties - compatibility and check compatibility with the version of the drivers you download. For example if you download the drivers for Vista check the Vista compatibility. Note that the Vista drivers are available for 64bit also.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.Thanks and regards
Please kindly rate this solution
Stelios
direct
fixya link: http://www.fixya.com/users/technical114
