The water supply cut previously during mid cycle. The water supply has since returned but the error message "no water check supply" keeps flashing up towards the end of each cycle. The water does not drain properly and the cycle never seems to finish as a result. The detergent is also not being properly drained from the drawer.
SOURCE: Machine stops in Rinse & Spin Cycle & leaks water
suspect problem is that water is not draining fast enough so when machine gets to spin there is too much water present which gets thrown up thro thew soap drawer. check the filter. on many hotpoint filter is not obvious. at back, take off bottom panel. you will see a large dia hose going from bottom of machine to pump. undo this hose at the tub end and the filter is inside it. be carefull. if you havn\'t managed to drain, a lot of water will come out. if this doesn\'t work, get back to me if you want
SOURCE: Not draining
it will be the pump they have a small fan inside them they get weak and with the pressure of the water they stop spinning which doesnt push your the water through the motor fast enough to drain properly replace and you will see the difference
SOURCE: F-05 error message on Hotpoint 860
I actually found it was the pump but not that it was faulty. When we took it out there was a hair stretchy ( like a rubber band) wrapped around the wheel stopping it from working properly. Took that off and it is now working perfectly. Even big wads of hair can do that so even if it doesn't seem to be blocked take the wheel out of its casing and have a good look at the spindle.
SOURCE: Hotpoint Aquarius WMA56 wont drain properly water leaking onto floor
pump is working water is only a trickle coming out so wont final spin
SOURCE: Hotpoint WD440 1400 Spin
There has been an unbalanced load and the machine could not spin
(see ‘Automatic Features’, Starting and Programmes).
Has the drain hose been installed correctly (see Installation)?
Are the drain hose, standpipe or undersink connections blocked?
Has ‘Rinse Hold’ option been selected? If so press the Rinse Hold button
drain hose make sure there are no kinks and the end is over the top of washer to drain this ensures that there is no back flush with drain pipe
clean the dispenser drawer regularly
Clean and dry the dispenser
drawer, syphons, grate and
fabric conditioner exit channel
(A). Also regularly clean the
outlet pipe area
Never force the machine door: this could damage
the safety lock mechanism designed to prevent
any accidental opening
