There seems to be two issues. 1. when i have batteries and a memory card in it will say batteries are empty. 2. when i put new batteries in it will say memory card is dirty. after that it will say batteries are empty. yes, the batteries are new when i try these. what do you suggest?
SOURCE: Camera does not work when memory card is inserted
just look in the slot for a short circuit. some times it does hapen on cf cards or on xd cards.
SOURCE: new memory card
did you formate it in the camera or your pc? formate in the camera first and is there a lock switch on the card?
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Make sure you are inserting memory card correct, and pini are clear.If is possible try another card.
Have a look at following link instructions.
http://www.olympus.co.jp/en/support/imsg/digicamera/download/manual/esystem/man_e300_en.pdf
SOURCE: Camera says Memory CARD FULL--but it's empty
Olympus cameras are a bit picky! If you have not already tried then format the card on the camera. This is more reliable than formatting the card on a PC.
Downloading the pictures from your camera does not erase them from the card. It only copies them to your PC
Hope this helps
