SOURCE: change analog scanner to digital
With my scanner, I could not change to digital. As far as I know you cant
SOURCE: want to convert analog police scanner into digital
Some scanners are capable of digital (APCO25). The BC248 however is not. You'll have to buy newer equipment.
SOURCE: BC340RS want to listen to digital police
This usually means a software package that is capable of decoding digital.
Most bearcats are pretty good in the digital area.
It some cases it may even mean a slight modification to the scanner.
You should be aware however that scanner use in the US has quite strict legislation which in some states may prohibit the decoding of such signals so please check first.
A good source of information are the two sites below
Frequencies
Scanner software
These may also help you find out if it legal or not in your state
SOURCE: can you convert radio shack pro 2038 base police
Sorry, but there is no way to convert an analog scanner to receive and process digital transmissions. Your only alternative is to purchase a digital scanner, and current models are in the $500 range.
SOURCE: How do I look for Police frequencies on my Radio
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Need the manual for your scanner? You can download/print it here:
http://www.uniden.com/pdf/BC60XLT-1om.pdf
BillB
