20 Most Recent Samsung Digimax D53 Digital Camera Questions & Answers
Go to the following url and you will find the driver and manual: http://www.samsungcamera.com/customer/download/cus_down_main.asp?page=6&keyfield=&key=
Samsung Digimax... | Answered on Nov 12, 2019
when you format you camra you can not retrive the picture you lost, you best way is to but a SD card from your local wal-mart and save you pictures on that in stead of you camras hard drive.
Samsung Digimax... | Answered on May 27, 2019
I have had success with this photo recovery program... Download the program from
http://download.cnet.com/Asoftech-Photo-Recovery/3000-12511_4-10913438.html?part=dl-10913438&subj=dl&tag=button
You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.
Samsung Digimax... | Answered on May 20, 2019
http://www.samsungcamera.com/popup/download.asp?prol_uid=2689&prj_uid=585
visit this link to get your manual for D53... thanks
Samsung Digimax... | Answered on May 07, 2019
The easiest way to transfer images is to put the media card into a card reader attached to your computer.
Samsung Digimax... | Answered on Apr 29, 2017
If indeed the batteries are brand new and without a doubt charged,
then you definitely have a hardware problem in the camera.
You're probably going to have to give it in to be serviced.
Hope I helped!
Tom
Samsung Digimax... | Answered on Jan 18, 2017
LOOK IN COMPUTER, IT SHOULD SHOW YOUR CAMARA THERE
Samsung Digimax... | Answered on Sep 21, 2015
Try the button that has a trash can on it.
Samsung Digimax... | Answered on Apr 01, 2015
Could be that your batteries do not have enough mAH? They should be at least 2600mAH. Any thing less than that tends to not have enough power to keep your camera on. I've used rechargeable batteries in the range of 1200mAH and they would not keep the camera on for more than a few seconds.
Try a hard reset by holding the power button down and removing the batteries at the same time, still holding the power button down go back and insert the batteries, it should reset it self in most cases? Another possible problem your camera might have is a stuck barrel lens, if it was dropped or has some sand in the lens gears, that could also make it shut down immediately.
Samsung Digimax... | Answered on Feb 23, 2015
check if the lock "switch" is in the up position, like on the photo.
Samsung Digimax... | Answered on Feb 12, 2015
If you mean the memory card itself, then hold the card facing you and push the small grey plastic button on the left hand side of the card to the up position, that should unlock the memory card. It is not really a button but more like a slide type of button.
Your camera will work with AA batteries.
Always be sure the batteries are charged.
Insert the batteries correct plus to plus and minus to minus. Only one battery the wrong way around and the camera won't work.
Check contacts of the batteries and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera.
Always charge the batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Also check if the battery door is closed correct. Most cameras do have a switch connected to the battery door. If the switch does not work correct, it could be you can't switch on your camera.
Do not use alkaline batteries unless it is absolutely necessary. In most cases, alkaline batteries have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera. They can't deliver enough power and can start leaking, causing damage to your camera.
Samsung Digimax... | Answered on Jan 06, 2015
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo management program such as Picasa.
Organize edit and share your photos
Samsung Digimax... | Answered on Nov 15, 2014
Why does the camera turns but the screen is black and won't take a photo? PLEASE RE-PHRASE THE QUESTION. THANK YOU
Samsung Digimax... | Answered on May 29, 2014
@ alan o'brien, Samsung D53 digimax draws a lot of current from the battery thus, you need to replace your batteries with a HIGHER current ratings, sufficient enough to run the motor. This miniature motor inside the D53 camera drives the reduction gears functions, to extend and retract the mechanical lens. During this processes it is drawing a lot of current from the battery. In order to conserve and prolong battery power avoid zooming in and out, utilize the function speed 50-400 and manually adjust aperture to minimize the unnecessary use of flash. In other words, go manual mode. Here's the battery specs. 2800ma NiMH rechargeable battery. Refer and follow manufacturers recharging instructions for best result. Do not leave batteries inside the camera even when not in use because the circuit inside is still on the standby mode and not necessarily off. Hope i have satisfy your curiosity. If you can, kindly share with me some of your best photo taken from your D53 digimax. Thank you.
Samsung Digimax... | Answered on Apr 16, 2014
Samsung Digimax D53 Digital Camera Logo
378 questions posted
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
View Most Popular
DigiMax Samsung
  • DigiMax Samsung
Most Popular Question
went using camera all beep shuts down
  • Cameras
