SOURCE: refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
SOURCE: Fridge and freezer not cooling down
It seems it's the defrost sensor (freezer side). Waiting for it to come, ordered this morning. It appears to be a defrost fault, having read on the web it seems you can check the defrost sensor with a meter across whilst holding the actual sensor in your hand tightly to see if the resistance changes, anyway it didn't. Will post when the new one comes and I change it.
SOURCE: My Kenmore side by side refrigerator is not freezing nor cooling.
surfgl,
The model you posted does not help me much but a rough estimate would be (from Sears) about $400.00 for the compressor + about $225.00 Serv Call and Labor. Possibly another $15.00 access valve and then tax.
The problem you have is that the compressor is locking up then it may run again for a short time. It will eventually lock up and not run again. If you can prove it is (by receipt) that it is less than 5 years old, Sears will repair it free under the sealed system warranty.
The model # and serial # should be on a sticker in the top front of the ref section. If not then on the left wall or right wall top front of ref section.
If this helped please rate me good. supertechks
SOURCE: Fridge worked perfect for 3yrs, one day i took
you may have a big problem not sopose have the door open so long better you call service
