Onkyo TX-8211 Receiver Logo
A
Anonymous Posted on Jan 10, 2014
Protect mode - Onkyo TX-8211 Receiver
Polk audio pa660 is in protection mode how do I reset it.
Lots of help in the links
Amp goes into protection mode - Polk Audio Forum
https://forum.polkaudio.com > discussion > amp-goes-i...
Nov 26, 2018 - As the title says , my 4 channel amp goes into protection mode when I turn my volume up to about 18-20 , causing a loss of sound .
Solution to my Protect Mode Problem - Polk Audio Forum
Feb 15, 2010
Speakers causing the Power Amplifier to go into protection ...
May 9, 2016
PA D4000.4 starts up in protect mode? - Polk Audio Forum
Aug 22, 2012
PA880 Help Needed - Protection Light - Polk Audio Forum
Apr 3, 2013
More results from forum.polkaudio.com
Protection Light ' Polk Audio PA660.4 Support - HelpOwl.com
https://www.helpowl.com > PA6604 > Troubleshooting
Jul 31, 2017 - Polk Audio PA660.4 - How do I turn off or get out of protection so I ca.
Car amplifier(Polk Audio PA660) question - Badcaps Forums
https://www.badcaps.net > forum > showthread
Dec 19, 2013 - The amp, is a Polk Audio PA660. It was entering in protection mode. I have found a pair of final transistors shorted at one of the ...
Amplifier Protection Mode Troubleshooting - Car Audio Help
http://www.caraudiohelp.com > newsletter > amp_prote...
One of the more confusing car stereo problems can be when an amplifier goes into protection mode. One minute it's working and the next minute it's not, ...
7helpful
What's your problem?powerprotection mode unlock
If the protect function works and causes hindrance to trouble shoot, cancel the protection function as described below, and it will be possible to enter the self-diagnostic function mode. (The protection functions other than the excess current dtect function will be disabled.)
While pressing the "Tone Control" and "Info" keys, press the "Power" key to turn on the power and keep pressing those 2 keys for 3 seconds longer.
The seld-diagnostic function mode is activated with the protection functions disabled.
In this mode, the "Sleep" segment of the Flourescent Display flashes to indicate that the mode is self-diagnostic function mode with the protection functions disabled.
Caution!!!! Usiong this product with the protection function disabled may cause further damage to your unit, so use special care when using this mode.
4helpful
In my samsung champ mobile one message had came in this message the protection mode is on and when I off the protection mode or try to delete the message the phone get restarted
51helpful
3answers
Kenwood car stereo cd player reads protect mode how do i fix this
i have a kenwood kdc-241 car stereo and it has gone onto protect mode i have done everything it says in the manual and even taken it out of the car just in case it was damp i have tried putting it back in but still is in protect mode can anyone help me please
4helpful
Stuck in protect mode
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
Protection mode
It's normal for some amps to go into protect for a few seconds when initially powered up. If it remains in protect mode, it may have shorted output transistors. To eliminate other possible causes, read through the following troubleshooting page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
How do I take my AG-8520 Audio/Video Receiver out of Protect Mode
go to the help and support section of your laptop, and type in protect mode. This should pop up a list of options for you to take it out of protect mode.
10helpful
3answers
Shuts off protect mode
i have a jvc stero and every time that i turn it on ...it show protect and shuts off!
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
