Onkyo TX-8211... | Posted on May 30, 2017 | Be the first to answer
Onkyo TX-8211... | Posted on Jun 19, 2014 | Be the first to answer
Onkyo TX-8211... | Posted on Jun 11, 2014 | Be the first to answer
Onkyo TX-8211... | Posted on Apr 20, 2014 | Be the first to answer
Onkyo TX-8211... | Posted on Mar 30, 2014 | Be the first to answer
Onkyo TX-8211... | Posted on Jan 11, 2014 | Be the first to answer
Onkyo TX-8211... | Posted on Jan 10, 2014 | Be the first to answer
Onkyo TX-8211... | Answered on Dec 12, 2013
Onkyo Audio Players & Recorders | Uploaded on Oct 15, 2013
Onkyo TX-8211... | Answered on Jul 02, 2013
Onkyo TX-8211... | Posted on Apr 28, 2013 | Be the first to answer
Onkyo TX-8211... | Answered on Apr 27, 2012
Onkyo TX-8211... | Posted on Sep 13, 2011 | Be the first to answer
Onkyo TX-8211... | Answered on Jul 30, 2011
Onkyo TX-8211... | Answered on Jul 20, 2011
Hi
Check the "Balance" control on your receiver amplifier.
Check all connections and cable to the inoperable exterior speaker.
1. Disconnect the "working" outdoor speaker from your receiver amplifier connection/ channel. Switch the cable from the non-operating speaker from its current connection to the working speaker connection. If the speaker now works fine, the problem is with the receiver amplifier.
2. Reconnect as original. Remove the speaker cable at the "working" speaker directly and connect it directly to the non-working speaker. If the speaker now works the problem is somewhere in the original speaker cable.
3. If the speaker still won't work then the problem is in the speaker.
Please get back to us if you have further query else please accept the suggestion.
Onkyo TX-8211... | Answered on Apr 29, 2011
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Onkyo TX-8211... | Answered on Mar 19, 2011
34 questions posted
257 Questions
251 Questions
159 Questions
132 Questions
-18 Questions
