Coby MP301 MP3 Player Logo
A
Anonymous Posted on Jan 10, 2014
Firmware reset - Coby MP301 MP3 Player
Nelson Sithagu
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 27, 2014
Nelson Sithagu
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
175
Points
How can I resset my firmware on macboopro
My alcatel lucent is stuck on the initialisation mode where it keeps displaying **4029 v3.80.90**
Here are some steps you can try to resolve the issue:
Reset the phone: You can try resetting the phone to its factory settings. To do this, you need to press the "Menu" button, select "Settings," then "Phone Settings," and finally "Reset Settings." This should reset the phone to its default settings.
Update the firmware: If resetting the phone doesn't work, you can try updating the firmware. You can download the latest firmware from the Alcatel-Lucent website . Once you have downloaded the firmware, follow the instructions provided by Alcatel-Lucent to update your phone's firmware. ALCATEL-LUCENT 4029 OPERATION MANUAL Pdf Download ' ManualsLib
If neither of these steps work, it might be best to contact Alcatel-Lucent customer support for further assistance.
Factory reset
To do a proper factory reset, you need to re-load the firmware.
The firmware and instructions for your tablet is here.
Support Firmware
Need to reset handset
IP Reset
IP Reset returns the basic network settings to their factory defaults. You can perform this operation from the
base unit or one of the handsets.
The following settings will be reset to their factory defaults:
DHCP setting (restored to DHCP on
• Settings related to static IP addressing (the values for static IP address, subnet mask, default gateway,
DNS1, and DNS2 are cleared)
• DNS settings for DHCP connection cleared
1.2 Reset and Firmware Update
1.2.1 Reset
1.2.1.1 Resetting the Network Settings IP Reset
Performing IP Reset from the phone user interface see 2.1.4 IP Reset restores the basic network settings
made through phone user interface programming or Web user interface programming to their factory defaults.
If the unit is unable to connect to the network after changing network settings, you can restore the network
settings to their factory defaults by performing IP Reset, and then try configuring the settings again. Settings
such as the phonebook data, are not cleared by this feature.
• DHCP setting restored to DHCP on
• DNS settings for DHCP connection (cleared)
• PHY settings (speed and duplex mode of the either LAN or PC port are restored to "automatic")
• VLAN (Virtual Local Area Network) settings (disabled)
• Terminal number settings (restored to "automatic")
Notice
After performing IP Reset, the unit will restart automatically. To avoid problems, it is recommended that
you save your settings before performing IP Reset.
Note
If these settings (with the exception of PHY settings and terminal number settings) were made through
Web user interface programming, the set values made through Web user interface programming
remain effective, even if you perform IP Reset. To reset these settings to their factory defaults, perform
Reset Web Settings from the Web user interface again.
Document Version
2010-08
Administrator Guide
www.InternetVoipPhone.co.uk ' [email protected] ' 0800 088 4846
Firmware Update
configuration file programming, the set values made through configuration file programming remain
effective, even if you perform Reset Web Settings.
Resetting the Settings Made through the Web User Interface
(Reset Web Settings)
Performing Reset Web Settings from the Web user interface see Reset to Defaults) resets the
settings made through the Web user interface to their default values.
When you use this feature, the unit will return to the status just after performing the most recent provisioning
or pre-provisioning.
Notice
After performing Reset Web Settings, the base unit will restart automatically. To avoid problems, it is
recommended that you save your settings before performing Reset Web Settings.
Note
The settings configured through the phone user interface only will not be reset. However, settings that
can be configured through both the phone user interface and Web user interface will be reset.
1.2.2 Firmware Update
You can update the unit's firmware to improve the unit's operation. You can configure the unit so that it
automatically downloads the new firmware file from a specified location. The firmware update will be executed
when the unit is restarted.
For details, see Section 6 Firmware Update.
Provisioning server
Firmware server
Configuration
file
A
Firmware
C
B
A Download
B Check for update
C Firmware download and update
34
Administrator Guide
Docume
Printer toner black reset firmware for samsung clx-2160/see
It seems that there are no Samsung CLX-2160 firmware reset/fix, if i'll find something i'll keep you posted
Have to keep reseting my router
Try to upgrade the firmware of the router. Firmware is the software of the router. Download the latest firmware of the router. Go to the manufacturer's web site and download the firmware of the router. Open the set up page of the router and upgrade the firmware of the router. Once you upgrade the firmware of the router, reset the router. On the router you will find a small reset button, hold it down for 30 seconds. release it. wait for 1 minute. Now unplug the power to the router and plug it back in. Now you will need to reconfigure the router according to the Internet service provider.
1helpful
I forget my sonicwall admin password how will reset this password
If the SonicWALL's admin password is lost, there is no backdoor or other mechanism to bypass the administrator login. Please note that prefs files do not contain the admin name and password. So if you reset the firmware and import a current prefs file, you can gain access using the default login credentials ('admin' & 'password'). Without a current prefs file, you must reset the firmware and configure from scratch.
For models running SonicOS (Enhanced or Standard), you can reboot to factory defaults. This resets all settings including the admin name, password and LAN IP address. Import the current prefs file. The configuration is restored and use the defaults 'admin' and 'password' to login.
For models running Firmware 6.X, you must reset the firmware (wipe and upload using the reset procedure). Import the current prefs file. The configuration is restored and use the defaults 'admin' and 'password' to login. The 'Reset to Factory Defaults' button does not reset the admin name, password or LAN IP address for these models
Can I reset the cd drive firmware?
uninstall the cd rom firmware from the device manager and install the new one that you have
1helpful
DWL 2700 AP wrong firmware install
hi...
since you upgraded a different firmware try updating the firmware again with the correct firmware if it works fine if it doesnot then the router had gone bad,,
and for GeminiBS reset the router to the factory default since the firmware was not done in a proper manner may be it had interruptions..once the hard reset is done the computer is restored back to the default so that you can use the device..
vedhick
2answers
Sansa e260 will not power up
Okay what you do for this is hold down the power button for 20-25 seconds or so. This will reset your Sansa e260 and then it will power up like normal. I have had this problem before. If that doesn't work then I don't know what will.
On start up
You have a firmware problem try updating the phone's firmware or take it to a mobile store and have the firmware reflash.
Top Coby Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
