Change Ink Cartridge in Epson Printer isn't a difficult. Just follow the simple steps to change ink cartridge in Epson Printer:
·Turn on Epson printer·Open its cover or scanner then left the unit of the scanner and wait for it.
·Ensure that the print head is at replacement position. If not the press "Maintenance" button.
Follow the more steps to change ink cartridge in Epson Printer.
OPEN SSC UTILITIES,DROP DOWN CONFIG BOX,SELECT RX420 MODEL,CLOSE
BOX,THEN RIGHT CLICK ON TRAY ICON AND SELECT INK FREEZER,AND RESTORE
VALUES BACK, OK ON COMPLETION,THEN RESTART YOUR PRINTER AND ALL SERVICE
LIGHTS SHOULD BE OFF.
IF YOU HAVE ANY FURTHER ISSUE LET ME KNOW
THANKS
KEVIN
SOURCE: changing an ink cartridge Epson stylus sx105
http://safemanuals.com/user-guide-instructions-owner-manual/EPSON/STYLUS%20SX105-_E
that guide shows how to change the cartridges and no you dont have to wait untill they have run out to change the cartridges
SOURCE: Epson cx8400 Black Ink Cartridge doesn't work on Printing
I put alcohol in inside the printer, where you insert the ink cartruges then cleaned with paper towl and it works for me.....
SOURCE: How to change ink cartridge in epsonnx110
Here is what I found on Epson Web site. Click on link below. IF YOU FIND THIS HELPFUL PLS RATE ME. THANKS AND GOOD LUCK......
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=128285&prodoid=63083739&category=Products
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Replace Cartridges Using a Printer Software Utility
For best printing results, use up a cartridge within six months of opening the package. If you need to replace a cartridge when the ink light is flashing or off (before the cartridge is expended), you can run the Ink Cartridge Replacement utility.
1. Windows: Right-click the printer icon in the bottom right corner of your screen (the taskbar) and select Printer Settings. Click the Maintenance tab.
Macintosh: Open the Applications folder, open EPSON Printer Utility3, select your printer (if necessary), and click OK.
You see one of these screen SEE ATTACHMENT BELOW
2. Click the Ink Cartridge Replacement utility icon and follow the on-screen instructions to replace your ink cartridges as necessary
SOURCE: changed black ink cartridge for epson stylus d120 but not working
Usually when this happens the printer fails to goes through
the motions of the printing process, kind of stands still with indicator lights
just blinking away. This could be as a result of either of these scenarios.
i.
Ink cartridge
has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink
is finished. You must replace cartridge one at a time). If lights stop blinking
it confirms that your cartridge has become incompatible or developed
incompatibility. Also if your printer is the type that can work with only one
cartridge, remove one after the other (closing back the lid/cover) to determine
which in the set (black or color) has become incompatible. At the instance the
incompatible one is removed and you close the lid, the blinking will stop (for
printers that can print with one ink cartridge only). Just replace the
incompatible one and start printing again. In most cases the issue is always
with one cartridge. But if both are affected, you have to replace both. Because
of this type of problem, always keep used cartridges somewhere safe; they come
in handy for this type of troubleshooting.
ii.
The Cartridge
electronic panel is dirty
The electronic panel on the cartridge that makes contact with the
cartridge carrier inside the printer is dirty and needs cleaning. This electronic panel is front part of the
cartridge with copper “dots”.
The
Solution is to try to clean this panel with a piece of folded tissue paper
soaked in a bit of methylated spirit. Also try to clean the area in the
cartridge carrier/holder that makes contact with the cartridge’s electronic
panel (Usually this is more difficult). If you cannot reach it with your
fingers, use a stick or something with tissue wrapped around it. Allow to dry
well and return the cartridges, close the cover. The blinking should stop if
the electronic panel is the issue. Once the blinking stops the printer will
print.
