If the lines are vertical to the direction of the printhead movement, you need to clean the paper rollers and the small "pizza wheels" of your printer. Also check for any traces of stuck paper in the paper path. I recon you ars not using genuine inks, right? Try to slow down your print speed by selecting a best quality setting.
If the lines are parallel to the printhead movement, your printhead is either clogged our stuck.
SOURCE: Epson CX6600 Skips every other 5th line when printing
Run the print head cleaning routine from the printers driver or control panel. you may have to run it 3 or 4 times to regain all the lines.
SOURCE: Epson 1400 Printing Orange colors Green
The problem can be two fold. Wrong cartridges, or blocked/damaged inkjet openings. Return it to the seller under warranty if its brand new. If it was fitted with non epson cartridges your warranty may be in question.
But I could almost guarantee the black qand the blue cartridges are faulty or their feed jets are
SOURCE: Describe your Epson Photo 1400 Stylus
: i'mma having problem with my epson 1400 it keep on having horizontal line on the picture after in clean the head and align it
