How do you set the scanner to your local police or
First you need to know what frequencies are in use in your area. For a comprehensive database, visit:
www.RadioReference.com
To enter (program) a frequency for future scanning:
- Slide the MODE switch to Scanner
- Press the E (PGM) key. This will turn on the PGM indicator at the top right of the display.
- Press the UP or DOWN arrow (above the SCAN and HOLD keys) to advance to the desired channel, OR enter the channel number using the keypad.
- Press HOLD
- Enter the frequency, including the decimal point (e.g. 155.67).
- To continue programming, use the UP or down key to advance OR enter a channel number, press HOLD, and continue programming as above.
When you're finished programming, press HOLD or SCAN.
I hope this helps. I have a BC370CRS on my desk, and I found that the programming is fairly simple -- once I got used to it.
NOTE: The BC370CRS will NOT work with trunked or digital radio systems. If these are in use in your area you will need a different scanner to listen in.
