The drop down menu on both toolbar and documents flashes and doesn't want to stay down or the menu on start button scrolls but it goes back up...scanned and checked but nothing came up help!
Toolbar extensions Search providers and Accelerators you have if don't need any of them you can disable or remove them.
also
alsoo Remove Cookies in Google Chrome
Anytime you enter a search query into the Google search engine or navigate to a website in the Google Chrome web browser, a file called a cookie is saved on your computer.
Cookies contain small portions of data that make web pages load more quickly, but they can also be used to find out what sites you are visiting and can even sometimes contain malicious code.
You can remove the cookies to keep your browsing history private.
Click the wrench icon at the upper-right corner of the Google Chrome web browser.
Scroll down and click "Options."
Navigate to the "Under The Hood" tab and find "Privacy."
Scroll down and click "Show Cookies" under the "Cookie Settings" heading.
Find the specific cookie you want to remove in the list of saved cookies.
Click the name of the cookie and then click "Remove."
Click the "Remove All" button at the bottom of the window if you want to remove all the saved cookies.
Click "Close" to save the changes and close the window.
http://www.google.com/support/chrome/bin/answer.py?hl=en&answer=95626
Manage your cookies and site data
also
aaaa
if you are using word open up word select view from the drop down list select toolbars select standard ,formatting
also open up word across to the left you will see arial,times new roman,arial black next will be more to name a few of the different languages from the drop down list your documents will be read in
also next to that will be a drop down list with all sizes you can change the sizes of text
open up a document you should a number of tabs at the top of your screen you should see a number with % percentage with a drop down list which has many zoom increases
if its a web page
right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar
this will add to your screen toolbar File Edit View Favorites Tools and Help select the view from the drop down list will be a Zoom with percentages %
if you need more help with this post a reply
hope this helps
also open up word across to the left you will see arial times new roman arial black next
if its a web page
hope this helps
if you are using word open up word select view from the drop down list select toolbars select standard ,formatting if you dont have these in the toolbar you will need to add them right click in the toolbar select menu
if you scroll to the top toolbar (top of screen) you will see the view tab select that then from the drop down list you should see a zoom with % and a text size with largest to smallest
when you want to print opoen the document select file then from the drop down list select print preview you could select edit then click select all and change the size of your print
hope this will help you
