Denon AVR-3805 Receiver Logo
Ian McDonald Posted on Jan 31, 2018
I would like to connect my AVR3805 output to a Bluetooth device so I play music on my new Boze Companion 3 system (this connects via Bluetooth on my laptop) - can this be done ?? - I presently have a surround sound hookup - other inputs but no other outputs - Thanks - Ian
5 Related Answers
Anonymous
  • 11 Answers
  • Posted on Apr 02, 2009
SOURCE: No system configration display on AVR3300 since moving.
Make sure the two switches on the remote are all of the way to left most position before you try using the SYSTEM SETUP button - if the AVR is going into SETUP, the LCD display should be saying "SYSTEM SETUP". (I think that model does - most do).  also make sure that the Composite or S-Video on the TV's input 1 work from something else like a VCR, DVD player, ETC. rule out the TV and the cable first.
Anonymous
  • Posted on Apr 29, 2009
SOURCE: Analog output from digital input for Denon AVR 3803
On the Denon AVR-888 (and I presume others), you have to put the unit in "record" mode. This is covered under "Other Operations and Functions" in the manual. Here are the steps:
1. On the front of the unit, press the zone2/rec select button
2. Turn source select until "recout source" is displayed
3. Turn source select to choose the input source
Hope this helps.
Matt
Anonymous
  • 11 Answers
  • Posted on Jul 08, 2009
SOURCE: Which optical inputs should I use for (1) audio output
Hi, the Optical and Coaxial inputs are assignable to whichever input you need them on. Plug the Optical cables from your DVD and HD cable box into any of the OPTICAL INPUTS (1 and 2 is fine, but write down your connections on paper)
You will then need to go into the setup of the AVR on the screen and assign the OPTICAL connections to the correct inputs (Probably TV/CAB and DVD.
Use the SYSTEM SETUP button on the factory remote, and you should see the on-screen menu appear on your TV. Go to INPUT ASSIGNMENT and choose the input for the DVD and assign OPTICAL 1 or 2...
Reply here if you need more help.
John Riley
  • 441 Answers
  • Posted on Jul 16, 2009
SOURCE: how to change the video output on denon avr 486
under the system setup menu go to video setup, and re assign the devices, then make sure the video output is assiggned to component as well. That should give you what you need
Anonymous
  • 71 Answers
  • Posted on Aug 11, 2009
SOURCE: Noise coming out of speakers connected to Denon AVR 1908
Check for nearby wireless devices and move them away. -If the audio output from the source device (i.e. DVD, CD player) is digital (i.e. PCM, DTS or Dolby Digital) you're on your own. I'd be willing to bet the output is analog (red and white RCA), because the "beeps" and "exploding sounds" you describe seem like it could be caused by interference. Try replacing the cables. Otherwise the issue is probably with your receiver.
2answers
How to fix Bluetooth wireless earbuds paired and connected to my device but no sound
Make sure that the pair on your output device states paired for phone and music. It can still pair for phone and data but not pair to stream music. This is common on android devices especially. If this be the case, unpair the device and forget (delete) the earbuds on your output device. Ensure any bluetooth devices like amazon Alexa, TVs and other common things are powered down. Turn the bluetooth on the output device off, then back on. Search for earbuds and follow manufacturer procedures to sync earbuds. Once found, pair. Ensure when a successful pair happens that they are paired for phone and music. It will tell you on the output device if the pair was successful for both. At this point make sure your volume settings are not muted or all the way down and you should be enjoying music if you have an app playing music.
3answers
Setting up Apple music on Echo dot
You Can Now Ask Alexa to Play Apple Music with Amazon Echo Controlling home by voice is going to be a lot of fun. Amazon Echo, a nine-inch black cylinder, is such a smart speaker that connects to the voice-controlled intelligent personal assistant service Alexa. You can use Amazon Echo to do certain things like play music, set alarms, make to-do-list, order items from Amazon, and control a smart home. To play an audio? It becomes extremely simple when having an Amazon Echo. Instead of tapping here and there on the phone, you only need to hook up your account to the Echo, then simply ask Alexa to play whatever you want. Unsurprisingly Echo includes Amazon's own music services, as well as some others such as Spotify, Pandora. So what about other streaming services such as Apple Music? Does Amazon open to have Apple Music on the Echo? Is it possible to stream Apple Music to Amazon Echo? The post would answer these questions and show you how to play Apple Music on Amazon Echo by asking Alexa.
Apple Music does not come to Amazon Echo
Amazon Echo is capable of playing music from other sources and streaming music from various services, including Spotify, Pandora, iHeartRadio, and Amazon Music. How about Apple Music? Unfortunately there is no support for Apple Music at the moment.
When will Apple Music come to Amazon Echo? According to a report from Bloomberg, Amazon's Dave Limp was quoted as saying, "We'd love to have Apple, but they're not super big." Perhaps Amazon thought Apple Music is not quite big enough to consider integration even though Apple Music has already racked up more than 20 million paid subscribers in two years since announced in 2015.
Use the Amazon Echo as a Bluetooth speaker to Play Apple Music
Although Apple Music is not native supported by Amazon Echo, Apple Music subscribers can still stream songs through the device, it's just that they'll need to pair their iPhone or iPad to the Echo and stream it from their phones instead. For people who also want to play music from iTunes library with Amazon Echo, they should also make it via Bluetooth. In this way, Amazon Echo is used as a Bluetooth speaker which does not make it unique.
Here are the steps to stream Apple Music on Amazon Echo via Bluetooth:
  • Go to Settings. Then, tap on Bluetooth and toggle the button to the on position.
  • You'll now see your Amazon Echo device listed under My Devices. Tap on it and it'll pair with your phone or tablet.
  • Navigate to your Music application where your Apple Music are accessible and start playing them.
Now, Apple Music songs should be heard coming from your Amazon Echo device instead of your mobile device speaker.
Link Apple Music to Alexa on Amazon Echo Pairing your device with the Echo using Bluetooth and selecting it as the audio output is an option to stream Apple Music from your iPhone. It is not a bad solution. But if what you intend to do is get Apple Music on Amazon Echo by using Alexa, then uploading Apple Music songs to Amazon is a great way. You can upload your Apple Music collection to your music library on Amazon and then stream the Apple Music through your Alexa device.
Before importing Apple Music to Amazon, we still have one thing to solve. That is, removing DRM from Apple Music or the songs from Apple Music could not be recognized and uploaded to Amazon successfully. Here we use Apple Music Converter to convert Apple Music tracks and playlists to plain DRM-free MP3 to walk you through.
$39.95 Buy Now (Mac) $39.95 Buy Now (Windows)Click the + button on the top or anywhere on the center to open the Add window. The Apple Music converter detects the whole iTunes music library automatically, so that you could simply select any playlist you saved or any track you prefer, then press OK to confirm.
The chosen Apple Music songs are displayed on the main panel of the Apple Music Converter. Click the Gear button on the top right to open the Preference window where you could set the output format, audio quality, conversion speed and the way to organize the output file. For example, choose MP3 as output format, 320 kbps as output audio quality and 20x conversion speed.
After pressing CONVERT button on the bottom, the Apple Music songs are being converting to MP3 at a very fast speed with high quality one by one. The output folder destination can be found by History > Folder. The songs from Apple Music are now DRM-free and could be able to upload to Amazon for playback via Alexa.
Skill to Stream Apple Music on Amazon Echo with Alexa
Upload the converted Apple Music songs to My Music on Amazon from your Mac or PC, when finished, you can ask Alexa to play your Apple Music songs on Amazon Echo and control playback with simple voice commands.
  • Run Amazon Music app on your PC or Mac and log in your ID.
  • Drag and drop files from the folder where stored the converted Apple Music songs into the Upload selection.
You can see uploaded music, and music that's uploading, by clicking the Uploaded filter in the left navigation sidebar. Once the Apple Music songs are imported to Amazon Music, you can play them on Echo or Echo Show speakers with simple voice command via Alexa. Speak "Alexa, pause" or "Alexa, next" and the music will pause or skip to the next song. You can also ask for Alexa to play music by genre, decade, mood, tempo, activity, and even lyrics. Amazing!
JBL Charge 2 stopped wifi connecting to pc
Problem connecting Windows 8.1 pc to JBL Charge bluetooth speaker ...
answers.microsoft.com/.../windows/.../windows8...connecting-windows...
When I try to connect the pc through Bluetooth to the above wireless speaker ... 2) What is the model of the JBL Charge Bluetooth speaker? ..... I am already able to play music from my iPhone 5 on this speaker via Bluetooth with no problems.
Cannot connect JBL Charge Bluetooth - Networking, Internet ...
en.community.dell.com/support.../network...wireless/f/.../t/19525571
Dell
Sep 22, 2013 - 16 posts - ‎11 authors
23 Replies; 16 Subscribers; Postedover 2 years ago ... I'm trying to connect my JBL Charge Speaker bluetooth with my Dell Studio 15 laptop to listen .... I am having the same problem, did you find a fix for this? ... not support audio output, then you need to add a Bluetooth adapter which includes a CD driver.
JBL Charge 2 ' Portable Bluetooth Speaker with USB Charger
www.jbl.com > Wireless > Portable Bluetooth Speakers
JBL
Rating: 4.3 - ‎110 reviews
Most popular JBL Charge 2 wireless portable speaker can charge any devices via USB... You can easily connect Charge 2 to any Bluetooth-enabled device by giving the portable's ..... Charge with proper charger or a USB port form computer.
Unable to connect Sony Xperia Z1 to Altec Lansing T515 bluetooth portable speaker
1 does it have bluetooth
2 is it turned on
3 have u searched for devices i.e. in settings -- music -- play over bluetooth -- select device i.e. Portable Sound System Device / Click / Ok / Play?
HOW DO I LOAD MUSIC ON MY BLUEDIO HEADSET FROM MY MINI MAC
Hey Ronald!
To be able to load music onto your Bluetooth Headset, you're going to first want to connect the headset with your Mac! To do this use the following steps:
Step 1: Click on the Apple logo in the upper left of the Mac, then choose System Preferences. Inside of System Preferences, choose Bluetooth.
Step 2: This screen should show a list of Bluetooth devices connected. Make sure the "Bluetooth is Turned On" on the Mac. You can toggle it on the left side. Make sure the Headset is currently turned off.
Step 3: Once the Headset is turned off and the Bluetooth on the Mac is turned on, turn on your Bluetooth Headset to place it into Discovery Mode. Keep an eye on your Devices list because once it appears, select it from this list.
Step 4: After it's been chosen from this list, you will now have it as an Output Audio device. You can always double check this in System Preferences in the Sounds section, on the Output tab.
Next, we want to be able to play music through that Bluetooth Headset. Go ahead and open up iTunes or try playing a video on the Mac Mini to ensure the audio is received!
I have linked two articles from the Apple Support website which may offer some additional assistance:
OS Mavericks Use Bluetooth headset with your computer
http://support.apple.com/kb/ht3563
Good Luck!
1helpful
Bluetooth connected to x5 but can't play music
You'll have to confirm this with BMW as we have a 650, 135, and X3 not an X5, but your car won't play iphone based music via bluetooth. It will sync contacts, make calls and some other things (particularly with the newer apps) but it won't play your music.
To play your music you have to have the package that allows you to connect your iphone via an iphone cable (usb at one end, iphone connector at the other - what you use to charge it). With this connected you can then see all your music and control your iphone through the screen on the dashoard.
Feb 07, 2013 • 2005 BMW X5
1helpful
When I have my headphones in the volume works but when I take them out it dosn't work anymore
THIS MAY HELP!
For PSP Go owners, a very cool feature is the ability to pair bluetooth devices with the system. This recipe will show you how to toggle between outputting audio between the PSP Go’s speakers/headphone jack and a bluetooth headset/speaker.
1. Pair your bluetooth device with your PSP Go.
-Go to Settings > Bluetooth Device Settings
-Be sure to turn the Bluetooth Connection ON. Then select Manage Bluetooth Devices.
-Click on Register New Devices; put your headset into pairing mode and pair it with the PSP Go by following the onscreen prompts.
2. Once your headset/device is paired. Be sure to leave the Bluetooth Connection on.
3. Finally, open up the music player or a game and when you want to switch between the PSP Go’s speaker or your headset, just hold the Audio button on top for about 7 seconds. It will change the volume icon w/a bluetooth icon and audio on your PSP Go should start outputting via your headset.
To toggle back to speakers/headphones, again hold the audio button for about 7 seconds and it will switch back.
This should work with any bluetooth headset and does not require it being a stereo headset (ie any $5 headset should work).
"This device has no output controls" Bose Companion 5 problem!
Metal detectors/ Xray devices have been known to destroy magnet based electronics (speakers). This could be your problem.
T Mobile Wing bluetooth and music help please
Hi fazioli73,
With Bluetooth enabled cell phones, if it has a music player, the only device the music player will recognize to output audio is a set of Bluetooth Headphones, not a Bluetooth Headset.
Once you have the Bluetooth Headphones, set them into pairing mode. Then go into your Bluetooth options in your phone, and go into add/search for device. Once your phone recognizes your Bluetooth headphones, and you have it set as your main Bluetooth device, your music player should play through the headphones at that point.
Sincerely,
Gina, Communities Connection Manager
Creating meaningful communication in a virtual world
CAN'T GET MY MUSIC PLAYER TO PLAY VIA MY SBH-170 BLUETOOTH HEADSET
I think the samsung T629 does not have stereo bluetooth. It would have to have a 2.0 class bluetooth profile to play music through the headset
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
