Amana 19.7 cu. ft. / 558 liter Upright Freezer Deepfreeze AFU2004AW Logo
Posted on Oct 16, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Freezer frost I have a 5 year old freezer that I do not believe is a frost free model. It is frosting up pretty good inside, we ar having to manually defrost is twice a year? the door seal does not look bad or have any cracks that I can find. Any suggestions?
  • Johnlib Feb 19, 2008
    I have an Imperial freezer which I'm told is or was made by Amana. The Model # is UL2494ECW8. It is not self defrosting and I have to defrost it a couple of times a year. Today I noticed the food on the bottom was not frreezing and starting to defrost. The frost buildup was severe so I defrosted it and it seems to be running kind of warm. It has a quick freeze switch and I'm trying that now. I think the door seal is bad becuase it used to hiss when I closed the door, creating a vacuum. It doesn't do that anymore. What do you think?
  • clrossi Nov 15, 2008
    I know that this post is about a year old, but I have an Imperial freezer as well and it is doing the same exact thing. The top shelf is about 4-5 inches thick with frost but the food toward the bottom of the freezer is no longer freezing. Were you able to find a solution to this problem?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 22, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
1113
Points
I had the same problem with mine (same model number). The top shelf started having a pretty serious ice build up and the lower shelves were not as cold as they had been. We defrosted by pulling out a button that did a defrost cycle, but after that it never got as cold again (hovers around 20 F) amd the hiss is not as pronounced when the door closes.
Has anyone figured out what this might be?
And can someone explain the quick freeze?
Anonymous
Level 3:
  • Master 473 Answers
  • Posted on Oct 16, 2007
Anonymous
Master
Level 3:
Answers
473
Questions
Helped
451996
Points
1483
An upright freezer that is not frost free will have the coils in the shelves (shelves are non-removeable) and that is where the frost will buildup.  If your model is like this then it will have to be defrosted periodically.  If your not sure then give me the entire model # from the sticker inside the freezer and I will look it up for you.
How do you make a freezer frost free?
Frost free means that the evaporator coil will not accumulate a thick layer of frost. It will not prevent frost from accumulating on the walls of the freezer. To slow down the amount of frost build up inside the freezer, do not keep the freezer door open for any longer than necessary. The freezer door seal may be defective. This would allow moisture in that would freeze on the inside walls. A heater with timed intervals to come on is one way for a frost free feature. But this will not work for frost build up on the inside walls of the freezer. It would only melt the frost and then it would refreeze again.
Our Frigidaire frost frost free upright freezer from day one has frost build up on the food inside the packages. The frost is not a problem in the freezer itself, but on the food. Freezer burn occur
Hi Dale Dibb, thank you for your inquiry!
I understand that the food inside of your Frigidaire freezer is getting frost on the inside of the packages. I would recommend turning the temperature up inside of your freezer. Additionally moisture inside of the package would cause frost to develop on the inside of the food packages.
Please assure that all possible moisture has been removed out of the food packages prior to placing the items inside of the freezer. If there is anything else that I can help you with, please feel free to reconnect! -Matt
Freezer compressor gets hot
Check behind and underneath for dust buildup, sounds like your compressor needs cleaned on the outside, the dust is causing it to overheat and retain condensation, hence the ice buildup. Easy thing to check, good luck.
1helpful
2answers
Is a Kenmore upright freezer model 253.23424102 frost free?
No it is not frost free. You can get the manual on the link below to read about the freezer and learn how to defrost.
http://www.managemylife.com/mmh/owner_manuals/134/KENMORE-Upright-Freezer-L0307021?brand_name_search=253.23424102+
Good Luck and please rate 4 thumbs up for the free answer.
1helpful
My amana upright gets cool but not cold enough to freeze probably not even as cold as a fidge. the problem started when we moved and stored it out in a shop that was partially heated. since then we have...
Good day,
Somewhat handicapped not knowing if it's a conventional freezer or frost free.
1. If it's frost free check to see if the fan motor is running in the freezer compartment.
2. As well if it has a fan motor in the compressor compartment, see if it is running as well.
3. If it is a conventional model, make sure it is turned on and make sure it is running. If running, then it has lost it's refrigerant charge or the compressor has lost it's pumping capacity.
4. If it is item 3, then unless it's less then 5 years old, the sealed
system/compressor problem is so pricey that it's not a practical repair. If under 5 years Amana will pay for these repairs, whether it's conventional or frost free.
Frost-free fridge-freezer; internal floor icing up
drain plug and or line probably plugged should be clear if ice was problem in between the casing shouldnt be a problem let unit run normal and check temp the amount of high humidity and usage [open and closing of doors] has caused a lot of frost free and regular units to frost and or ice up
Sep 29, 2009 • Freezers
Freezer frost
That you have to 2 defrost your freezer it's normal depending of many factors. Do you open it often, is it in a warm place, is the food that you are putting in it is warm? many factors contribute of building up frost faster.
Francois
Dec 29, 2008 • Freezers
1helpful
Not all shelves freezing Alarm on
If this is not a frost free unit. I say replace it. I don't believe in recharging a deep freeze. You can never really trust them again. The food inside is worth more than the freezer. If this is a frost free unit, See if the fan inside is working. This can also be a defrost system proplem such as a timer and well worth fixing.
Kenmore® (46-26072) Elite® 20.6-Cu. Ft. Frost-Free White Upright Freezer
Check these two things first.  1.  Is there a thick frost buildup on the back panel at the bottom half of the freezer?  2.  Do you hear the fan running inside the freezer?  Let me know what you find.
Top Amana Freezers Experts
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you an Amana Freezer Expert? Answer questions, earn points and help others
