20 Most Recent Amana 16.8 cu. ft. / 476 liter Upright Freezer Deepfreeze AFU1705B Questions & Answers
Amana self defrosting upright freezer - drain plug
The subject is a Eureka Model 350 hand held steamer that can be found at Lowes and other places for around $49.95. With this steamer you can thaw out an evaporator as quick as if you were using a heat gun or hair dryer but without the slightest concern about melting plastic or wiring. By using steam instead of pouring water (yes many still do) there is little to clean up. With the many attachments it comes with there are other uses (i.e. cleaning, thawing drains, thawing IDI fill tubes, etc.). The steam also makes the replacement IDI fill tube (rubber end) more pliable and easier to complete the installation when used at the end.
This unit has a trigger and can be used to blow out a stopped up drain on a refrigerator by letting the pressure build up a little then blow through the drain with one of the attachments. As for thawing out evaporators it had a fine jet tip for actually CUTTING through solid ice.
Another great use for this tool is refrigerator door gaskets. The hot steam works faster than a heat gun with out the worry.
Note: Do not aim steam directly onto the plastic freezer liner. The rapid temperature change could damage the liner.
9/25/2014 10:08:44 PM • Amana 16.8 cu.... • Answered on Sep 25, 2014
How to i can uninstail or remove deep freezee in
The best solution for this is to Disable with Anti DeepFreeze! You can get the two versions from this blog If you have forgot your pass or has been crashed then you can fix it with Anti DeppFreeze, You can get two versions free from this blog: http://deepunfreezer.blogspot.com/
1/21/2011 6:18:03 PM • Amana 16.8 cu.... • Answered on Jan 21, 2011
5answers
How to uninstall deep freeze from your pc?
how yto uninstall deep freeze, password forgotten
1/21/2011 6:13:58 PM • Amana 16.8 cu.... • Answered on Jan 21, 2011
I fail to uninstall deep freez from my computer.
If you have forgot your pass or has been crashed then you can fix it with Anti DeppFreeze, You can get two versions from this site: http://deepunfreezer.blogspot.com/
1/21/2011 6:08:08 PM • Amana 16.8 cu.... • Answered on Jan 21, 2011
Freezer door does not seal
you can actually bend the door into shape if you can see that it is warped. If the freezer hing is on that corner then you can loosen the screw on that side and push the door into place and re-tighten the screws. You need a big screwdriver and a big person to get it done. you can test the repair with a dollar bill. Slip it in and close the door. It should take a little pull to pull it out. Go all around the door like that. anywhere it slides out easily you will have an air leak..
9/22/2010 5:32:41 AM • Amana 16.8 cu.... • Answered on Sep 22, 2010
The freezer was left on and it began to defrost.
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
8/26/2010 12:03:59 AM • Amana 16.8 cu.... • Answered on Aug 26, 2010
How to replace freon in a amana upright freezer?
This is one of those thing that need to be left to an EPA certified tech, You need a recoverey tank/bag and gauges to check to see if that is even the problem.
8/19/2010 9:53:50 PM • Amana 16.8 cu.... • Answered on Aug 19, 2010
Freezer not cold water on bottom of freezer how do
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
8/12/2010 3:30:14 AM • Amana 16.8 cu.... • Answered on Aug 12, 2010
Our freezer was left open
It should reset itself once it gets cold again which could take a day. if that doesn't do it turn freezer off and on again see if that will do it
8/10/2010 3:48:03 PM • Amana 16.8 cu.... • Answered on Aug 10, 2010
Fost accumilating inside
There are three components that control the automatic defrost cycle.
#1 is the defrost timer, this is a simple clock and set of contacts that switch from cooling mode to defrost mode every 8 to 10 hours. The timer knob can be turned clockwise slowly until a positive 'click' is felt, this is the defrost mode. Let it sit there for about 10 minutes and you should hear the hiss or sizzle, if not then we go a bit deeper.
#2 defrost heater, this heater is located on the bottom of the cooling coils behind the back panel in the freezer, it will run long enough to remove the frost from the evaporator coils and turn off by the defrost terminator or no longer than 25 minutes maximum
#3 defrost terminator or thermostat or bi metal, 3 names same part. This is clipped on to the evaporator coils near the top and senses the temperature, it is there so the defrost cycle does not run too long.
4/24/2010 7:10:39 PM • Amana 16.8 cu.... • Answered on Apr 24, 2010
I can't use my hard disk after i installed deep freeze
WITH CTRL+ALT+SHIFT+F6 IN YOUR MONITOR WILL APPEAR A WINDOW.THERE YOU WILL CHOOSE BOOT THAWED AND THEN YOU WILL HAVE AN ACCESS IN YOUR HARD DISK.
10/31/2009 8:50:20 PM • Amana 16.8 cu.... • Answered on Oct 31, 2009
Amana 25. cu ft..freezer not working...making rattling noise now and then
Check the defrost timer, rotate it until a solid click is heard. If your unit starts to work replace that timer. Good Luck
8/5/2008 2:34:05 AM • Amana 16.8 cu.... • Answered on Aug 05, 2008
Door seal
i wouldn't worry about vacuum seal. door gaskets contain a low powered magnet around the entire face for "contact" seal, id look into perhaps something placed on one of the shelves or door blocking the door from closing as tightly as you remembered. if you have a problem with that gasket. it would have to be physically ripped and where it didn't make contact you would have an influx of warm air resulting in ice balls forming inside door liner adjacent to seal
3/3/2008 2:08:47 AM • Amana 16.8 cu.... • Answered on Mar 03, 2008
Freezing
YOU COULD GO TO THE AUTO ZONE AND BUY A TAP VALVE AND FREON 134A CHARGE IT THROUGH THE LOW SIDE SHOULD READ 5 AND HIGH 150 USE 134A. IT MIGHT WORK FOR A FEW MONTHS TO A YEAR IF NOT LONGER BUT YES IT HAS A LEAK THE CONDENSOR IS BUILTIN AND MADE OUT OF STEEL AND IT RUST THROUGH OUT THE YEARS THEY SHOULD OF USED COPPER NOT STEEL
8/30/2007 12:14:03 AM • Amana 16.8 cu.... • Answered on Aug 30, 2007
2answers
Amana bottom freezer, all working OK, but very noisy freezer. How do I fix it?
There are a few potential causes of a noisy bottom freezer. Here are some things you can try to fix the problem:
  1. Check for frost buildup: Frost buildup can cause the freezer to become louder as it has to work harder to keep things frozen. To check for frost buildup, remove all items from the freezer and unplug the fridge. Then, use a hair dryer to melt any frost that has accumulated on the evaporator coils (usually located behind the back panel of the freezer).
  2. Check for loose parts: Some common sources of noise in a freezer are loose screws, washers, or other small parts. Check for any loose items and tighten them as needed.
  3. Check the evaporator fan: The evaporator fan is responsible for circulating air within the freezer. If the fan is not working properly, it can cause the freezer to become noisy. You can check the fan by removing the back panel of the freezer and listening for any unusual noises. If you suspect the fan is the problem, you may need to replace it.
  4. Check the compressor: The compressor is responsible for circulating refrigerant and cooling the freezer. If the compressor is malfunctioning, it can cause the freezer to become noisy. You can check the compressor by listening for any unusual noises or by checking the compressor with a multimeter. If you suspect the compressor is the problem, you may need to replace it.
If you are unable to fix the problem yourself, you may want to consider contacting a repair service. They will be able to diagnose and fix the issue more accurately.
1/4/2023 5:58:02 AM • Amana Freezers • Answered on Jan 04, 2023
Amana 16.8 cu. ft. / 476 liter Upright Freezer Deepfreeze AFU1705B Logo
22 questions posted
Top Amana Freezers Experts
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you an Amana Freezer Expert? Answer questions, earn points and help others
View Most Popular
Amana Freezers
  • Amana Freezers
Most Popular Question
uninstall deep freeze from pc
  • Freezers
