I did a master reseal on a 3.4 , the drive system is new. The coolant system new
The 3.4L is known for blown head gaskets. I personally have repaired over 30. One of the first signs is air in the cooling system and loss of heat. The best way to tell is to chemical test the cooling system to see if there are CO2 gasses entering the cooling system. I've seen people bleed the system and it is fine for a while, but believ me this is a blown head gasket.
Does your thermostat open? Upper radiator hose get hot? If it fails to open correctly it can cause the pressure to go over the limit and vent while driving. Also if your radiator is plugged same thing can happen. Is the radiator evenly hot when engine is warm?
A head gasket has worn down on a water jacket to the point that allows air to enter the cooling system from the combustion chamber. First thing I'd check.
Sounds like the head gasket. When you did the reseal are you sure you didn't cut a gasket.
Check head gasket !
Start engine with water pump belt disconnected.
Open rad cap and if you see air bubbles the head gasket is
blown.
If yes go to Napa and get Pills to put in the rad to fix the blown gasket.
You need to "burp" the system. There should be a coolant nipple (bleeder valve) at the highest point of the cooling system. You will have to locate it. Start the car and let it warm up to temperature then open the bleeder valve. Air mixed with coolant will come out. When there is no air, only coolant coming out of the bleeder valve, close it and you are done,
On some of these cars even when you bleed them manually they still airlock in the intake this is caused from a air bubble getting trapped under the thermostate which will not allow it to function properly. These cars are also known for the intake gasket corners blowing out and also the timing chain cover gasket blowing out this will cause a very small leak that will cause what you are experencing unfortunatelly these leaks are very hard to find there is a dye you can purchase that will help you pinpoint such a leak under a uv light which is avalible from local part stores like napa, if you do not have such a leak then you will need to get a the system depressurised and actually suck the coolant into the system , with a specialised vacuum pump this is actually a specialty tool that the factory uses to fill the system on the assembly line you can purchase this tool from mactools ,snap on , napa , etc. it is rather inexpensive usually under a hundred bucks however you will need air pressure to use it so if you don't have a air compressor avalible for use don't waste your time. bring it to a local oil change place, they usually have this tool on hand and charge less than 40 bucks to flush and fill your coolant system, just make sure you don't have one of the leaks I mentioned earlier cause they will try to fix it for you , and that can get pricey unless you have experience with wherever you bring it never let a oil change place repatr your car
Welcome to FIxYa.com
How to Fill Coolant If the coolant system has been flushed, first add 100
percent ethylene glycol in the amount listed for the appropriate engine application.
Then slowly add clean water to the system until the level of the coolant mixture
has reached the base-of the radiator neck. Wait for two minutes and recheck the
level of the coolant mixture. add clean water if necessary to restore the coolant
mixture level to the base of the radiator neck When refilling the engine cooling system, add three engine
coolant supplement sealant pellets, GM RN 3634621 or equivalent, and GM
approved new Ethylene Glycol Coolant DEX-COOL GM RN 9985809. If the cooling system is being refilled ONLY (no flush), a
50 percent ethylene glycol and 50 percent clean water mixture should be used to
fill the system. Fill the system until the level of the 50150 mixture has reached
the base of the radiator neck. Wait two minutes and recheck the level of the coolant
mixture. add a 50/50 ethylene
glycol water mixture as necessary to restore the coolant mixture level to the base of the radiator neck. Install the radiator cap making certain the arrows line up with the
overflow tube. Close all air bleeds.
DO NOT over torque the air
bleed valve. The air bleed valve is made
out of brass. Fill the coolant
reservoir with a 50 percent ethylene glycol and a 50 percent clean water coolant mixture. The proper amount of this mixture to
be installed into the coolant reservoir is listed below: Add 0.65 liters (0.68 quarts) of a 5010 mixture of ethylene
glycol and clean water to the coolant recovery reservoir. CAUTION: The low coolant indicator lamp may come on after
this procedure. After operating the vehicle so that the engine heats up and cools
down three times. if at any time the "TEMP' warning indicator comes on. Immediate
action is required.
Air bleed vent is at the thermostat house
Thank you for using FixYa.com
Regards, Lee Davidian
