20 Most Recent TaoTao Manufacturer Inc Youth Skateboard & Protect Gear Combo / Black Skull Questions & Answers
You need a stator puller. It is a specific tool that pulls stator off tapered shaft
TaoTao... | Answered on Dec 16, 2019
go to motorpartsmax.com. they should be able too help you .
TaoTao... | Answered on Mar 26, 2017
Hi, Anonymous before testing any electrical component in the Starting Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Engine Run Switch is "FAULTY" or corroded.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
5. Bank angle sensor needs a reset or is faulty.
6. FOB battery low or dead.
7. Faulty ignition switch.
8. Faulty starter button.
9. Faulty kickstand, clutch, neutral safety switch.
10. Security alarm needs a reset.
11. Starter relay, solenoid, starter motor or circuit wiring faulty.
12. Starter armature or field coils have failed.
13. Main fuse or circuit breaker may be blown or faulty.
14. Faulty ignition relay.
15. The electric starter is working but starter clutch has failed.
16. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
https://atvconnection.com/forums/1-engine-problems/323218-150-cc-taotao-won-t-start-no-spark.html
Scooter Troubleshooting Scooter won start All about Scooters
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
https://www.taotaopartsdirect.com/collections/paladin-150
TaoTao 150cc Scooter Owners Manual
TaoTao... | Answered on Dec 17, 2019
Check jet to see if its clogged in bottom of carburetor
Best and cheapest option is to order tumbler which will come with keys. Just search google for tao tao moped / scooter ignition with keys - They are cheap
More info would be nice, but,...
It's probably carbureted, if so, First things first, is there a petcock (valve on the tank? Are you sure it's on? If it is, Move the quad into a well-ventilated area, shut off the fuel, preferably by the valve on the tank. (If there is no valve, pinch the fuel line), pull the fuel line off the carburetor, then try draining a small amount of fuel into a gas can, watching how much fuel comes out, then replace the fuel line, ensuring it's on all the way. If the stream of fuel was about the diameter of the inside of the hose, your problem is probably downstream, in the carburetor. (I would look at the float being either stuck or out of adjustment, then see if there is something stuck in the orifice the float's needle valve rests against.) If the stream is more of a fast or slow drip, something is plugging your fuel system. The first thing I'd look at is the filter.
TaoTao... | Answered on Jan 05, 2019
Hi, Steve, I would love to help you with your engine or chassis noise but I just loaned my brand new pair of listening ears to your local dealer's chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. If you are a little short on "DRACHMA" and a Dealership is not on your list of fun places to visit then perhaps the list below will help soothe your worried mind so you can make an informed decision.
1. Bearings---SCREECH---WHINE
2. Belts---CHIRP
3. Brake Rotors---BUZZ
4. Cam Chains---CLICKIT
5. Clutches---CHATTER
6. Cylinders---PING
7. Fairing Panels---WHISTLE
8. Fenders---SCRAPE
9. Fronk Forks---Plunk
10. Fuel pumps---WHIRR
11. Gears---WHINE
12. Head Gasket---HISS
13. Hydraulic Lifters---TAP
14. Instrument Clusters---BUZZING
15. Kick Starter---GRINDS
16. Pistons---SLAP
17. Power Valves---CLINK & RATTLE
18. Radiators---GURGLE
19. Rear Chains---RATTLE
20. Rear Shocks---SQUEAK
21. Relays---CLICK&BUZZ
22. Shaft Drives---WHIRR
23. Shifting Trans---CLUNK
24. Solid Lifters---TICK
25. Speedometers---bzzz
26. Starters---CLICK
27. Starter Clutch---GRIND & WHIRR
28. Rods Go---KNOCK-KNOCK---who's there, it's me "*****"
Scooter Troubleshooting Scooter won start All about Scooters Tao Tao ATV wont start Fix it here
https://www.taotaopartsdirect.com/collections/lancer-150
TAOTAO QUANTUM 150 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
TaoTao... | Answered on Apr 28, 2018
Hi, Bob for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Amazon com Poweka New 39mm Air Filter Gy6 Moped Scooter Atv Dirt Bike...
TaoTao 50cc Scooter DIY Air Filter Replacement PT 1
TaoTao Scooters Mopeds Parts
TaoTao ATM50 A1 Owner Manual
TaoTao... | Answered on Mar 01, 2018
Hi, Brad for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your TaoTao, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Taotao ATM150 Evo scooter replacement of fuel and vacuum lines
Taotao ATM150 Evo scooter fuel tank vent line gas leak fix
http://absolutelyscooterparts.net/pdf/CGen_GY6_50cc_Service_Manual.pdf
Eagle Atv Parts
TaoTao... | Answered on Dec 01, 2016
cvc
TaoTao... | Answered on Oct 27, 2016
there is a wiring plug under the seat it may have a come out or the wire has corroded., also check the earth it is around the same area.
TaoTao... | Answered on Oct 21, 2013
Hi Tiffany the best thing u can do is youtube go to the website and type in blower motor replacement and there are tons of videos but there all not going to b the same but I'll bet there's one for your car have a grand day regards Chris
Motorsports | Answered on Dec 21, 2018
Once you have disassembled the motor and pulled the armature from the field windings you will need to have an ohm meter. Set the meter to OHMS and then touch the red lead to the winding lead on one end and the black lead to the winding on the other end and if the windings are still good you should be a 0.00 reading or very close depending on the resistance. The reading should be close to the same as touching the red and black leads together. This means that there is a complete circuit end to end and the winding is not broken. IF the meter does not give you that reading you will have a broken winding.
Motorsports | Answered on Oct 29, 2018
Check all fuses and if good you will have to pull the covering from the rear hatch to get at the wires so you can check with a test light or volt meter to see that you are getting voltage when the wiper switch is activated. If there is no voltage try to see if the wire is damaged somewhere or if the switch itself has gone bad. If there is voltage them the motor may be burned out. You will have to have the things that you find replaced if bad.
no, it is per car, not per team surely. Here is some reading for you.
Competitors are allowed only a limited number of tyre sets during a race event: thirteen dry, four intermediate, three wet. Each tyre must be marked with a unique identifier for tracking and scrutinising during a race event. During the practice sessions drivers are limited to the use of three sets of dry tyres, and certain sets must be returned to the supplier before the second and third sessions. If qualifying and starting the race on dry tyres, drivers who complete a lap during the third period of qualifying (the top ten) must start the race on the tyre set with which they recorded their fastest time during the second period. Any cars that qualified outside the top ten may start the race on any remaining set of tyres. Cars must race on any two dry compounds during a race unless intermediate or wet tyres have been used by that car in that race.
If driver crashes out can he give his remaining tires to team mate Google...
Formula One regulations
Motorsports | Answered on Jul 29, 2018
If my memory serves me correctly the dash needs removed (hard work) and work then easy
Motorsports | Answered on Feb 04, 2018
great mercadolibre com mx http://www.soccerphysicsonline.com/
Motorsports | Answered on Jan 15, 2018
you need to post what engine you need firing order for
Motorsports | Answered on Nov 30, 2017
TaoTao Manufacturer Inc Youth Skateboard & Protect Gear Combo / Black Skull Logo
3 questions posted
Top TaoTao Manufacturer Inc Motorsports Experts
HeadnSouth
Level 1 Expert
Andrew Taylor
Andrew Taylor
Steve P
Steve P
Are you a TaoTao Manufacturer Inc Motorsport Expert? Answer questions, earn points and help others
View Most Popular
  • TaoTao Manufacturer Inc Motorsports
Most Popular Question
get
  • Motorsports
