Husqvarna 125bvx Hand Held Blower Vac Logo
A
Anonymous Posted on Dec 01, 2013
125b carb problems - Husqvarna 125bvx Hand Held Blower Vac
Gas coming out exhaust on 125b husqvarna leaf blower why
Check the carb. sounds like the needle valve is stuck open allowing to much fuel the enter the piston cylinder. Carb. probably needs to be rebuilt.
Gas is leaking from husqvarna 125B blower when priming
Either the return line to the tank from the primer has a hole in it, is broke, disconnected; or the diaphragms in the carb are stiff and the unit is flooding
5helpful
2answers
How to adjust carb screws on husqvarna 125b blower
You need a special carb screw tool for Walbro carbs. Readily available from eBay, search ''Carb Adjusting Tool for Partner/Husqvarna''
1helpful
Husqvarna only runs at half choke
Ours does the same thing. On Amazon you can buy the carb. adjusting tool for about $17 and will solve your problem. It solved ours.
Have a husqvarna 125b have spark and fuel wont start done every thing i know new plug rebuilt carb gaped coil im tired of pull on it any answers please help it
the rule of thumb is spark, fuel, compression. I found I gad a plugged air filter. It would not start until I removed it and tried to start.
The blower will not start. I changed the spark plug but it still will not fire..
Maybe you have some problem with the carburator. You can put some gas in the carb if it start and then turn out your problem was the carb.
I have a Husqvarna 125B handheld blower, will not stay running
probable clogged screen in carb. rebuild carb with a kit. also check fuel lines and fuel filter
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
