SOURCE: Problem with Epson CX5000 Scanner Driver
Download in google for free registry repair for VISTA and repair ur registry and try to install again...
Still not working,Try to install driver's on another location
And rate me as FIXYA please
SOURCE: my computor does not recognise my scanner
Hi
Pls check for updated driver for scanner on support.epson.com, because i believe that this printer doesn't have a wireless scanner server so the scanner will not work wirelessly.
Hope this helps
SOURCE: Epson Stylus CX9400 driver settings
Not sure how you're removing the driver, but if you go to control panel device manager remove the printer totally as an option; reboot and then reload the printer. You also need to identify the remote printer in the print sequence or as your default printer in set-up (device manager). Hope this helps.
