Sanyo VPC-S500 Digital Camera Logo
Posted on May 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Black screen Turn on the camera, the start screen shows up, then it turns black when ready to get pictures taken. Tried going through all menus, can see all menus just fine, didnt mess with anything. Tried every setting, still, nothing. Also, can see all saved pictures, and the other lens was cleaned off.
  • khein1985 May 07, 2009
    Sorry, forgot to explain further... cant see what pictures i take NOW with the black screen, only old ones saved.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 26, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
569
Points
Try cycling through the Display button until you're able to view photo to be taken.
Anonymous
Level 2:
Sergeant:
  • Expert 246 Answers
  • Posted on May 07, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
246
Questions
0
Helped
102651
Points
760
Try to take pictures even the LCD is black, if you can review the pictures you just took, your camera is ok. find 'DISP' button, press it to turn LCD on.
there is a post for your reference
http://www.myfixtips.com/blog/digital-camera/general-qa/no-display-on-lcd-screen-112.htm
Hi there, My camera dsc-w120 used to work fine,just recently when I turn it on there is only the information on black on display, it doesn't show what I'm pointing it at? Do you know why that could be or...
I have a similar problem on my DSC W320 just a black screen when using the viewfinder and when i press to take a picture it is still black. Everything else works fine, I can access menus, change settings, view pictures that were taken before this error. VERY STRANGE, please can you help!!!!
1helpful
Camera not displaying images as seen through viewfinder. The screen is black. Image controls and info can be seen but the picture is just black. Takes photos which are also black; but previous photos...
A stuck shutter is another common failure mode for digital cameras, particularly for the SD1000. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
By the way, my wife's SD1000 also has this problem every once in a while. I easily fix it by using the following steps from the link: powering on the camera, opening and closing the battery door, and flicking the end of the lens barrel with my fingertip (or you can tap it with a pencil as discussed in the link).
3helpful
I have a Cybershot DSC-S780
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
3helpful
2answers
Canon SD1000, screen blacked out and takes black pictures
try taking the batteries and memory card out let it set and put everything back in it ang cut it on
1helpful
My screen remains black before and after the picture is taken and i have tried hitting it with the palm of my hand...???
CCD FAILURE!
Call canon for Free Repairs it is a known manufac fault in thousands of cameras , dont worry just call them see this for info on this problem
Kindly Rate me WELL !
Service Advisory Link this applies to all products with same problem dont worry u r included just call them and tell them abt BAD CCD !
Good Luck !
KODAK eASYSHARE c530 BLACK SCREEN DOES NOT TAKE PICTURE
You may still be able to take pictures with your black screened Kodak camera. This problem occurs in the line of Kodak EasyShare digital camera models.
When you turn on your Kodak EasyShare digital camera, turn off the LiveView function. Take a picture using the small-windowed viewfinder (this is not the LCD screen). Also, try zooming in and out.
After taking a picture, review the picture to see if the picture has been taken. Then turn on LiveView and occasionally the LCD screen should no longer be showing a black screen.
Black Pictures
I tried snickos fix. but did'nt find the wire disconnected, Soooo I rebuilt the camera and hay presto, it works.. go figure..
Black Pictures
Do you have it in manual mode with too small an aperture and too fast a shutter speed?
2answers
Pentax Optio 555 LCD screen blank problem
No I don't believe it is your shutter, more than likely it is a LCD Screen problem. I would suggest you take your camera back to the shop where you purchased the camera and have it serviced under warranty. I had a customer with an Optio 550 come in and it looked like every shot was taken through 'venetian blinds' and the problem was with the LCD Screen and the camera was sent back to Pentax and repaired under warranty.
Top Sanyo Cameras Experts
NOEL
NOEL
Ngoro
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
