20 Most Recent HP Photosmart R717 Digital Camera Questions & Answers
HP Photosmart R series dock isn't charging my camera or the spare battery
hp photosmart r707 only red led on
1/23/2013 10:40:42 AM • HP Photosmart... • Answered on Jan 23, 2013
Need charger & manual lost when we moved
You may download a copy of the manual here. See page 193 for information regarding ordering accessories.
9/16/2012 9:21:22 PM • HP Photosmart... • Answered on Sep 16, 2012
HP R717 - lens stuck
Try the procedures in this tip.
9/16/2012 9:21:12 PM • HP Photosmart... • Answered on Sep 16, 2012
I need a copy of the disk that came with the
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
5/3/2011 5:51:33 PM • HP Photosmart... • Answered on May 03, 2011
Need drivers,
Hello robert_jim68,
Have you tried downloading the HP Photosmart R717 Digital Camera series drivers from this HP support link?
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=437793&lang=en&cc=us&prodTypeId=382085&prodSeriesId=437792&taskId=135
If this solution is helpful please click a thumbs-up rating.
Have a great day,
martyshaw152
4/26/2011 3:32:41 AM • HP Photosmart... • Answered on Apr 26, 2011
I have a hp r717
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Picasa or any other photo cataloging program.
4/2/2011 8:15:45 PM • HP Photosmart... • Answered on Apr 02, 2011
When I take a picture with my R717 and view the
Hi! Pretty much an optical lens issue. This is bout to reach its break point so be ready to replace it if it breaks down.
9/26/2010 9:58:48 AM • HP Photosmart... • Answered on Sep 26, 2010
2answers
Camera will not switch on
my camera will not show power when plugged into the dock, I had power from this before. Is it the dock or my camera that isn't working properly? Thanks Joanie October 2,2008
8/28/2010 4:56:58 AM • HP Photosmart... • Answered on Aug 28, 2010
Sd card issue
Having gone over a month with no response, I assume this is no longer a problem.
7/26/2010 8:58:20 PM • HP Photosmart... • Answered on Jul 26, 2010
Card locked
With the camera turned off, remove the memory card from the camera and switch the locking tab on the card to the unlocked position.
7/26/2010 5:41:05 AM • HP Photosmart... • Answered on Jul 26, 2010
The problem is it comes on and shuts right back
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
6/11/2010 10:01:03 PM • HP Photosmart... • Answered on Jun 11, 2010
Message unsupported usb cable when switched on
try using it on another computer.
6/11/2010 9:13:15 AM • HP Photosmart... • Answered on Jun 11, 2010
I can not find my book what size memory SD card
The R717 uses SD cards, which means it's limited to cards up to 2GB in size.
You can download a manual from the manufacturer's web site at http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=437502&lc=en&cc=us&dlc=en&lang=en&cc=us
5/18/2010 5:08:27 PM • HP Photosmart... • Answered on May 18, 2010
Can't download/transfer image from HPR717 camera to computer
Try using a separate card reader.
4/28/2010 10:21:11 PM • HP Photosmart... • Answered on Apr 28, 2010
When I go to load
First off, have you had this camera working on this computer before? Have you had this problem before? How long have you owned the camera? Did you install the latest software/drivers? Once I have more information I can assist you further.
Thank you,
Lee
2/4/2010 2:07:28 AM • HP Photosmart... • Answered on Feb 04, 2010
HP Digital Camera R717 Charging Flash Error
Try to run self-diagnostics test - press flash button while switching the camera on. One of them tests the flash functionality.
1/28/2010 10:21:21 PM • HP Photosmart... • Answered on Jan 28, 2010
Will not flash; display says 'charging'
Run self-diagnostics test - press flash button while switching the camera on. One of them tests flash.
1/28/2010 10:19:12 PM • HP Photosmart... • Answered on Jan 28, 2010
HP Photosmart R717 Digital Camera Logo
44 questions posted
Top HP Cameras Experts
 Mikey
Mikey
ADMIN Eric
ADMIN Eric
Are you a HP Camera Expert? Answer questions, earn points and help others
View Most Popular
PhotoSmart HP
  • PhotoSmart HP
Most Popular Question
only download photos not movies
  • Cameras
