20 Most Recent
Kodak EasyShare CX7300 Digital Camera Questions & Answers
The software will not upload on my windows 7 home
If you mean "install" instead of upload, then try installing using windows XP compatible environment.
Right click on the installer program and select PROPERTIES
select the COMPATIBILITY tab
tick RUN THE PROGRAM ...
select WINDOWS XP (SERVICE PACK 3)
click OK
If you mean "download", then try a different browser, or the link may be a dead link.
If you are just downloading the photos and movies from the camera, you can simply (with the camera off) remove the SD card and place it into a card reader on your computer. Please follow the normal practice of "ejecting" the card before removing it from the reader, or the reader from your computer.
What type USB cable needed to offload pics
You don't need a USB cable.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa (
http://picasa.google.com ).
Kodak easy share wont delete or scan to the left to view pics
In order to solve the problem you need to transfer pictures from the internal memory to the SD card and thereafter you will be able to delete the pics in the internal memory.
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card?
Answer :
Follow these steps:
- On the camera, press Review and then Menu.
- Select Image Storage.
- Change to Internal Memory.
- In the menu listing, scroll down to Copy, and select OK.
- Select a single picture, or select All.
- When you have finished copying pictures, reset the Image Storage location to your original setting.
Can't find original software for Kodak EasyShare CX7300 camera
You don't need any special software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Windows Photo Gallery or
Picasa.
Cannot transfer pictures to laptop
Picasa.
Lcd turns off
Hi,You probably have a malfunctioning charging unit, a bad battery, or a defective display,
Suggestions:- Borrow a compatible charger and fully charge the battery.
- Install a new battery and see if the problem persists,
- Replace the display though it's it's and expensive procedure for such an old camera. It will be much cheaper to go on eBay and upgrade your Kodak EasyShare CX7300 Digital Camera.
How to format sd memory
First, make sure you have an SD card and not an SDHC card.
Press the Menu button. Use cursor-up/down to highlight Setup (three horizontal sliders) and press OK. Use the cursor buttons to highlight "Format" and press OK.
I would like to format a memory card for Kodak
This can usually be done once the card is installed into the camera. There should be a way to FORMAT DISK with your camera settings. It is usually under MENU, Then you may see some icon with tools, scroll to that and then you should find FORMAT. Under FORMAT, you should be able to format your new memory card.
Hope this helps!
