Problem is when i am installing the hp lj 3055 at step 4 it stop the installation and shows the error " Either you are in safe mode or microsoft installer is not installed properly." then it generate error...
Hi kakurawat:
Do you meet these minimum system requirements?
Minimum system requirements
● Windows® 2000
● Windows XP
● Windows Millennium Edition (Me)
● Windows Server 2000
● Windows 98
● Mac OS X V10.3 and later
● 128 MB RAM for Windows operating systems
● 32 MB RAM for Macintosh operating systems
● 250 MB hard-disk space (full installation)
● CD-ROM drive
● USB port
Printer drivers
The all-in-one comes with software that allows the computer to communicate with the all-in-one (by
using a printer language). This software is called a printer driver. Printer drivers provide access to allin-
one features, such as printing on custom-sized paper, resizing documents, and inserting watermarks.
Supported printer drivers
The following printer drivers are provided for the all-in-one. If the printer driver that you want is not on
the all-in-one CD or is not available on www.hp.com, contact the manufacturer or distributor of the
program that you are using, and request a driver for the all-in-one.
NOTE The most recent drivers are available at www.hp.com. Depending on the configuration
of Windows-based computers, the installation program for the all-in-one software automatically
checks the computer for Internet access in order to obtain the latest drivers.
Operating system1 Fax driver PCL 6 printer
driver
PCL 5 printer
driver
PS printer
driver
PPD2 printer
driver
Microsoft® Windows® 98
Windows 2000
Windows XP
Windows Server 2003
Mac OS X V10.3 and
Mac OS X V10.4
1 Not all all-in-one features are available from all drivers or operating systems. See the context-sensitive help in the printer driver
for available features.
2 A Macintosh printer driver and the necessary PostScript (PS) Printer Description files (PPDs) are included with the all-in-one.
Additional drivers
The following drivers are not included on the CD, but are available from the Internet.
● UNIX® model scripts
● Linux drivers
● Windows XP 64-bit drivers
You can obtain Model Scripts for UNIX and Linux by downloading them from the Internet or by requesting
them from an HP-authorized service or support provider. For Linux support see www.hp.com/go/linux.
For UNIX support see www.hp.com/go/jetdirectunix_software.
Typical installation
The following software is included with a typical installation:
● HP ToolboxFX
● HP LaserJet Fax setup utility
● HP LaserJet Scan program and driver
● HP LaserJet Fax
● Readiris OCR (not installed with other software; separate installation is required)
● Printer drivers (PCL 6, PCL 5e, PostScript® Level 2 emulation [PS])
● HP Director (Macintosh)
● HP All-in-One Setup Assistant (Macintosh)
Minimum installation
The following software is included with a minimum installation:
● PCL 6 printer driver
NOTE Minimum installation supports faxing from the control panel.
Hope this helps
