SOURCE: I NEED BELT DIAGRAM FOR MY HUSQVARNA RIDING MOWER
http://www.usa.husqvarna.com/home.aspx try this out for your answers, I hope this helps you. MERRY CHRISTMAS!
SOURCE: My Husqvarna lawn tractor started smoking terrible
You mean Briggs and Stratton. Sounds potentially expensive. Call a local small engine repair shop. They'll tell you how much it will cost. A new engine might be $1k. Repairs a few hundred.
SOURCE: i have a 2005 husqvarna lawn tractor. 24 hp, 48 in
sorry. I don't have an ansewer for you however I might have some helpful hints. Your mower should be going dam near 5 MPH. But yes can't cut in reverse. you have a belt going from the trans axle to the motor. It could be slapping against the frame. The idler puller or the tension pulley could be wobaly where the bearings are gone out. If you remove the 4 bolts on the back of the mower under the seat and gas tank it should visable tell you the story. My question is mine hits gears real hard as if trans mission needs oil or internal damage.
SOURCE: HYDRASTATIC TRANSMISSION DOESN'T MOVE
Far as I know the warranties are not transferable. Some hydrastatic transmission fluid can be checked by removing the battery and underneath there is a place to put the fluid and to check it. But not all models or makes gives you this option.
SOURCE: husqvarna yth1848xpt with a kawaskie 20 hp puffs black smoke
I had the same problem with my YTH1848XPT . Believe it or not it is simply a dirty air filter....you must remove the filter and blow it out with an air compressor...or better yet replace it. you can not clean it well enough without the force of the air compressor. Mine works great now.
