Kohler Cimarron 2-PC Elongated Toilet with EcoSmart Technology, Left-Hand T... Logo
j
joan barrios Posted on Oct 31, 2013
Tighten seat The wing nuts will not tighten. Removed them to check, even when all the way up not even close.
Andrew J Kambites
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Nov 01, 2013
Andrew J Kambites
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
0
Helped
7509
Points
23
Try adding washers (stainless or brass) betwee the toilet body and tightning nut use as many washers as you need
andrew
How do i tighten soft close toilet seat on a porcher cygnet, with no underneath access to bolts.
There is usually a plastic nut that goes on the bottom and has a wing on it that will catch when you tighten the plastic bolt from above.
How do I tighten a wobbly soft close toilet seat?
There are two(2) nuts under the outside edge of rim of bowl(bottom section)right in front of tank. use fingers to tighten, and pliers to secure. If it will not tighten, then the posts molded in are loose, requiring replacement. Sometimes even if new on these types.
Aug 27, 2014 • Home
1helpful
I am trying to replace aleft rear turn signal bulb on a 2005 lacrosse. I removed two wing nuts but cannot remove assmbly. Is there another wing nut holding it in. I cannot find it?
3 wing nuts. here is the info needed.
gmlogoflat.gif Service Information
bhome.gifbpublication.gifbnumsrchbutton.gifbnews.gifymkbutton.giffeedback.gifbhelp.gif
2005 Buick LaCrosse ' Allure, LaCrosse VIN W Service Manual ' Body ' Lighting Systems ' Repair Instructions ' Document ID: 1537542 Tail Lamp, Turn Signal Lamp, High Mount Stop Lamp, License Lamp, Backup Lamp Replacement - Rear
Callout
Component Name
Notice: Refer to Fastener Notice in the Preface section.
Fastener Tightening Specifications: Refer to Fastener Tightening Specifications .
Turn Signal/Stop Lamp Assembly Replacement - Rear 1
Nut, Turn Signal/Tail Lamp (Qty: 3)
Tip
Pull back rear compartment carpet to gain access to lamp.
Tighten
2 N·m (18 lb in)
Lamp, Turn Signal/Tail Lamp
Tip
Twist the bulb socket and pull inward to replace the bulb.
License Lamp Replacement 3
Screws, License Lamp (Qty: 2)
Tighten
2 N·m (18 lb in)
Lamp, License Lamp
Tip
1helpful
2answers
The toilet see is not tight. How can I tighten the seat? I have an elongated seat with the soft closing lid.
Right behind the bowl on the underside there is a nut on either side that holds the seat on...tighten those nuts and it will tighten down the seat...
heatman101
My tap keeps leaking from the cartridge, changed t...
mAKE SURE "o" RING GROOVES ARE FREE OF DIRT . Then place the O ring ,putting some vaseline on the "O" ring. Then, placing the cover on, totate the cover as you tighten down knob or wing nut.. Just before it is too tight to turn, turn the cover one more time to evenly seat it. Finish tightening. DO NOT OVER TIGHTEN, COVER WILL DISTORT.
Good Luck
May 21, 2010 • Home
We have 3 soft closing Toilet seats.Newly installed.One has become very loose. Asking agent/ shop , they showed me how to remove on another modle. Press on white inside lift seat off etc and ecposes the...
Reach under the bowl of the toilet and feel for a rather large wing-nut bolt on each side of the toilet. You must hold these with your hand and tighten the screws with a screwdriver. If you don't hold these wingnuts, then the screws will keep spinning forever and never tighten. Run your hand directly below the toilet just below the screws and you will find them. VERY EASY FIX!
Top Kohler Home Experts
john h
ZJ Limited
ZJ Limited
Are you a Kohler Home Expert? Answer questions, earn points and help others
