hi! replacing cd room,open your cpu cover by two quick lock bolt at back side of your pc right side,show on figure w/ arrow where the quick lock bolt.
then pull out cover and you'll cd rack inside your cpu as shown on figure
release 2 lock screw,and pull out i.d.e cable on cd room terminal also the audio cable next to leftside if have one,next the front cover of cpu thats locking your cd room theres a cliff lock on side opposit of the fron cover lift it by flat screw driver slowly and careful it might broke,after cover was detouched,don't remove any wire connection on front cover,pull out your cd room replace by dvd rom and connect all what has been disconnect on cd room put back front cover,and connect pwer,audio and ide cable again then try to switch on your dvd rom is a plug and play you can install your dvd installer and follow wizard instruction and click finish...regards
