20 Most Recent
Mitel 5330 IP Phone Questions & Answers
HOw do you change the time on the mitel 5330 IP
You cannot change the time from the phone. Your system administrator must change the time in your PBX. If you have the latest version, you can have your PBX sync with an internet time server and will never have to update again!
Cannot put a call on hold and then place another call
other phone ?? what type of phone is "other" phone if its a normal landline provided by phone company, this is why your new ip phone works differently , as its sure capable of having multi lines but you'll need to contact your ip provider to see about getting a second (or more) phone line added to your account
How to change voicemail greeting on Mitel 5330
If you want to change your voicemail greeting, go into your voicemail and press 4 on the keypad. This is usually the number for personal options such as Voicemail greeting, name in the directory, and changing your voicemail password. If you need more specific instructions just let me know and I'll be happy to help.
How do i unlock mitel 5330
What model of controller do you have? There are several systems that this phone will work on. Mitel 3000, 5000, and 3300. Which model of main controller do you have? There are a few others but to answer this question more details are needed.
What does the display of the phone say?
HOW TO CALL FORWARD TO CELL PHONE NUMBER
There are a couple of ways to achieve this.
First, press 355 on your phone to activate the call forward feature. Once it asks for a forward destination, press whatever number your company uses to dial an outside line. After that dial your number like normal and hang up the phone.This will forward all calls directly to your cell phone.
The second method is the same as the one listed above but it uses the feature code 356. 356 will forward calls if you do not answer from your Mitel phone first.
I hope this helps
My message light is flashing even though I've
There might be another voicemail box associated with your extension. Hang-up the receiver and press the voicemail button. It should tell you where the voicemail is sitting. If you do not know the passcode for that voicemail, have your system admin take a look at it.
