Konica Minolta C6500 C5500 C6501 C6000 C7000 Developer Set C/m/y/k Dv610 Logo
A
Anonymous Posted on Oct 03, 2013
In PhotoShop CS6, whenever I click print settings in the Printer Setup area, PS crashes
1helpful
PS CS6 How to drag a layer into another PSD file at-size?
>Open "My Computer" from your desktop. Double-click your hard drive.
>Open "Documents and Settings."
>Open the folder labeled with your user name.
>Open "Local Settings" followed by "Temp."
>Scroll down to the files beginning with "Photoshop" ("PS" for older Photoshop CS builds). This will be followed by a series of letters and numbers.
>Double-click each "Photoshop" ("PS") temp file to open them in Photoshop CS. This is the only way to identify which temp file contains the project you wish to recover. Luckily, because when Photoshop shuts properly it deletes its temp files, there should be no more than three or four.
>Select "Save As" from the "File" menu when you find the temp file you want. This will make the file permanent.
also use Photoshop Restore Toolbox
http://www.photoshop.restoretools.com/
2answers
Photoshop prints only black and white
I don't know what you mean by 'set for color output', but be careful there is a way to set the printer's 'preferences' through the PS PRINT DIALOG BOX... those settings can be different than your regular printer settings. Look for it when accepting the send to printer parameters.
Gray color prints as brown using Photoshop CS6
check your image mode.. click image, then mode, then cmyk color.
21helpful
3answers
Kernell32.dll error on photoshop cs6
hi,
i downloaded Photoshop cs6 trial and when i click the Photoshop icon to open the software i get a window:
Photoshop.exe - Entry Point Not found
The procedure entry point GetLogicalProcessorInformation could not be located in the dynamic link library KERENEL.32.dll.
What can I do???
I have allready tried to reinstall....
still the same.....
HELP
5helpful
Pen pressure not working in Photoshop CS6
I had this problem
click on your brush menu and top right of that menu you will see a small icon with an arrow pointing down with 4 lines next to it, click on that then click Reset All Locked Settings.
This worked for me
Darren
1helpful
My Photoshop sends a print job 100 times to my Xerox 7800 instead of once for 100 prints.
I also have this issue running a xerox docucolor 550 and PS-CS6 the only soloution i have is to save the file as a pdf and send it from firey comand center if you are running a firey server command center is available from xerox website
Adobe CS6 Master Collection mac serial
You can get all the best Adobe software now at a much reduced cost in the Adobe CS6 Master Collection for just $151.00. It downloads directly from Adobe and there is not any Monthly Adobe Cloud subscription fee. It comes with all Popular Adobe software like Adobe Photoshop CS6 Extended; InDesign CS6; Illustrator CS6; After Effects CS6; Acrobat Pro; Dreamweaver CS6; Premier CS6; InCopy CS6 plus more, and as a Bonus lots of great Photoshop Plugins to make using Photoshop easier and much better. See it here.
http://www.perfect-shareware.com/adobecs6masterspecialoffer.htm
3answers
Cs6 autorization code
Adobe Photoshop 6.0.1 CS
PWW600R6862670-965
Adobe Photoshop 6 - Unlimited PWW600U4353670-298 or PWW600U2641042-866
The following downloads provide the Photoshop CS6 beta installer for Mac Note: You do not need a serial number to install and use the beta. Simply select "Try. I want to try Adobe Photoshop CS6 for a limited time." in the Welcome Screen when you start the installation process.
English
Download Photoshop CS6 beta for Mac (DMG, 984 MB)
hope it helps
2helpful
Hi, Whenever I try to print, I get the following message: Paper Size Mismatch. The duplex unit is only compatible with US Letter and A4 paper sizes. What do I do? I haven't changed my paper or...
Make sure the correct paper size is set on your computer before printing. With your file open, click File > Print > Properties > under Print Setup tab in the Paper Options area, ensure the correct Paper Size and Paper Type is set. Click OK to save the setting. Try to print again.
When printing photoshop .jpg only print quality avail. is BEST
Check settings in your Photoshop program.
then metch with Printer preferences (not properties)
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
