System error show E247 kindly confirm what is the problem releted this error
SOURCE: the machine shows the E007
the error E007 means - fixing film rotation error.
If you are not a tech you must call for one. He could replace the broken part for about 2-300$.
SOURCE: canon ir1570f printer system error E247
Hi rapsherp,
Cause: Error with Serial Number PCB or Counter PCB or Main Controller PCB
Remarks:
Please complete online form to order Controlled Parts via Dealer Net or
Canon Intranet, and send to Information Management Group.
The E247 code relates to a problem with either of the above
three boards, which are a controlled parts from Canon with the exception
of the main controller.
If you change any of the above boards the other two must come from the
same machine as they each 'write' to each other to ensure everything
matches up.
Given the age of these machines and the cost of the boards it would be
cheaper to upgrade to a newer model.
Hope this helps.
Thank you for using FixYa.
