SOURCE: Internet hesitation
Both of your browsers may be conflicting with one another until one is sucessful.Try to disable firefox and only have i.e. If this clears your problem than you need to chose which one you want.Let me know.
SOURCE: compaq pc, dual boot xp home/hp/pro
2 things. First, when you say xp/pro wiped out your modem do you mean your ethernet or internal modem? Assuming it's a cable/dsl modem, I'd reboot the modem. Then while booting into xp/home, I'd copy the driver .inf file for your ethernet and paste it to a "public" folder (non system folder, desktop or another HD will work). Then re-boot into xp/pro and do a hardware scan and install the ethernet using the driver that you copied. This should get you on the internet using xp/pro. If you're getting the same cable unplugged error after all of this, you may just have a bad ethernet cable or connection. Good Luck Patty!
Open Internet Explorer by clicking the Start button . In the search box, type Internet Explorer, and then, in the list of results, click Internet Explorer.
Click the Safety button, and then click Delete Browsing History.
Select the check box next to each category of information you want to delete.
Select the Preserve Favorites website data check box if you do not want to delete the cookies and files associated with websites in your Favorites list.
Click Delete. (This could take awhile if you have a lot of files and history.) Close IE8 and reopen a new window.
