20 Most Recent
D-Link DIR-625 (790069292637) Wireless Router Questions & Answers
I was trying to connect
I also meet this problem, I use the portable mobile internet, when I try to rename it, it name became HT-AP0. Here are the content I learned from computer eginnering, you can try to reset your network( it should be a bottom you can press), or you can try to let the electrode shortcircuit, and erase the imformation. cause this phenomeon is because of hacking. Unfortunately my network's reset bottom is broken. So good luck to you!
I am not a native speaker so forgive my word mistakes! THX!
How to configure D-Link Wireless Router 615 on LAN ?
you need a cat 5 or better to work fine, and if you have turned mac filter on, please check/add if needed your laptop to the network, best is to use dlink given cd, with has auto-detect devices function inside, then adjust security setting manually
DIR 625-reset name and password
Since the router has reset itself, you can login it very easy. Go your web brower and in the space for the url address type 192.168.0.1 It will then bring up a screen for user name and password. The user name is admin and the password is left blank. Once you enter that information your logged in.
Good Luck
Mark
D-link 625: have lost disk
You do not need the disc. Using you browser, login into the router using the default IP 192.168.2.1 unless this has been changed and you should be able to configure your router.
Dlnik dir-615 all lights flash
If rebooting or a complete factory reset did not solve the issue, I believe your ROM or other electronics may be defective. I had a similar issue with a D-Link router several years ago, probably due to a power surge.
192.168.1.1 password
A password for the router login or a wireless password?
For the router login the default is "admin" and no password. Go to your settings and find the Wireless section and the password should be there.
For the password to the the router itself, you will have to perform a factory reset by locating a small hole on the back of the router, then using a pencil/pen of tip of a paperclip and inset it into the hole for about 10 seconds with the power on.
Cannot configure D-Link DIR 625 wireless router
Hey Raj - Unplug your modem and router. After 60 seconds plug your modem back in. When the lights return to normal (except the activity light) , plug your router back in. Give it 10 seconds and try it. If this solves your problem PLEASE rate this as fixed. If not, DO NOT RATE YET. Just add a comment letting me know what happened and I'll be happy to assist you further. Thanks.
Jeff
Where is the access point on a pixma mg5422
Do you have a wireless router that has a 'WPS' button?
If so, press that button on the router, and press the similar button on the PIXMA, and the two devices should connect.
D-link DIR-625 wireless router is setup and wired to laptop
First of all make sure the Wireless switch in your Laptop is turned on.
Now Disconnect the cable from the Laptop to the Wireless router
Now go to your Wireless Network connection and search for the available network. Select the appropriate network and connect.
Thanks
Wps button
The front of your Actiontec modem has a button and light for Wi-Fi Protected Setup (WPS). If that button was pressed or the WPS process was started, that button may light up or blink.
