System recovery is only really needed if you have malware infections that can't be removed by anti-malware programs or if you've had your computer for years and never bothered to clear out the rubbish that accumulates over time. If you clean your computer and scan for malware regularly (once a week for both) then you should be able to delay having to use System Recovery. I use my computer A LOT and use System Recovery about every 2 years.
Here are some links for cleaning software and anti-malware that are all excellent products and totally free :
1/.
http://www.piriform.com/CCLEANERRun cleaner then registry - fix issues
2/.
http://advanced-systemcare.en.softonic.com/downloadRun deep care cleaner, then open Toolbox and run Ram cleaner deep scan, then minimise. Get to know the toolbox, it does some amazing things.
3/.
http://download.cnet.com/Auslogics-Disk-Defrag/3000-2094_4-10567503.html?part=dl-6267754&subj=dl&tag=buttonAnalyse your hard drive then defragment & optimise.
4/.
http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?part=dl-10804572&subj=dl&tag=buttonRun scan for malware and follow instructions if any is discovered.
If you use the 2 cleaners and the malware scanner once a week your system will function well. The cleaners take a few minutes & the malware scanner about 30 mins.
You should only need to use the defrag once a month. This takes about 30 mins.
If you've used these and there is no major improvement then System Recovery is your only option.
Don't forget to reload all of these tool after System Recovery and use them regularly as I've recommended & you will keep your computer running really well.
I hope this helps.
