20 Most Recent Acer Aspire 4530-5889 Notebook PC Questions & Answers
try to reinstall your drivers
Got to http://gd.panam.acer.com/home/
Select the computer model
Select Operating System
Click Drivers
Select Camera (Suyin) and download it.
Once downloaded install it on your computer.
Acer Aspire... | Answered on Apr 05, 2015
what should i do?
Acer Aspire... | Answered on Mar 23, 2015
try going to device manager and uninstall then reinstall your dvd driver
Acer Aspire... | Answered on Mar 03, 2015
Cleaning the registry may help.
Acer Aspire... | Answered on Feb 28, 2015
USB Flash Drivers are an automatic install and so should work out of the box. If they aren't then can you try another flash drive? Can you also try and use another known working device in that same USB port? Is it the USB port that is damaged? Does the PNY work in another computer?
Acer Aspire... | Answered on Oct 29, 2014
port could be bad if so you can pick up an ethernet to usb adapter really cheap.
Acer Aspire... | Answered on Sep 29, 2014
No drivers are required for a Crystal look, the Crystal display is part of the screen manufacture and is not driven by software, it is the glossy sheen on the screen, you will have to contact acer tech support to see if a Crystal display is available for your model or buy a notebook with a Crystal look display.
Acer Aspire... | Answered on Jul 25, 2014
try shift+2
Acer Aspire... | Answered on Apr 26, 2014
go to control panel and "sound" and check settings.
If your regular speakers are working, then your headphone jack is broken and must be replaced. If neither has sound, try reinstalling the sound card driver available from the laptop manufacturer's website.
Acer Aspire... | Answered on Oct 17, 2013
Press and hold the blue function (Fn) button and F7. This turns the touchpad on and off.
Acer Aspire... | Answered on Jul 05, 2013
Hey, I've just been having this problem. Try pressing CTRL + SHIFT + FN all at the same time. I found out that I had to press them once to turn on the green keys, and then press them twice more to turn it off. I hope that works for you.
Acer Aspire... | Answered on May 02, 2013
Try here: http://support.acer.com/product/default.aspx?modelId=16 You can verify with a Ethernet Cable connected to the ISP Modem.
Acer Aspire... | Answered on Dec 26, 2012
First, altering the BIOS or the system registry is like taking a stroll in a minsfield, nothing good usually come form it. Second, What is running in background that will slow down the system. Disable all processes that are not needed at startup of computer. Also you can open "Task Manager" and end processes that are not needed, for instance "Windows Search" it's a memory hog. I have no idea what is running in background on youd laptop. If you have a program, if not, CCLEANER FREE found here: http://www.filehippo.com/download_ccleaner/ Install and use often there are useful TOOLS such as STARTUP where you can disable startup programs that will speed up your laptop. Take a look at this procedure: http://www.techrepublic.com/blog/10things/10-ways-to-speed-up-windows-7/3332 ALSO I use a Program, when I play graphic intensive games Game Booster: http://www.techspot.com/downloads/4842-game-booster.html Respond to this post for further info.
Acer Aspire... | Answered on Dec 05, 2012
is your Hard drive Detected by the computer? check it in Bios if it is detected or not,if it is detected then select first boot device as Hard drive. still you are getting the same problem then there might be chances that your OS is corrupted and you need to re install it.
Acer Aspire... | Answered on Nov 15, 2012
first make sure if you have any cd in the tray or usb connected. If yes, remove these and try reboot. if problem still persists, use boot disc that your manufacturer supplied to repair your laptop.
Acer Aspire... | Answered on Aug 24, 2012
Acer Aspire 4530-5889 Notebook PC Logo
254 questions posted
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
base system devices tanda seru
  • Computers & Internet
