It's the type you twist to stay open and I don't know how to get inside of it to connect the device to help it stay open.
Do you have the type that has a lever on the wall of the tub? If so, remove the two screws tat hold it on and pull out the whole assembly that will be connected to it. It is the spring that is worn out behind the lever and needs to be replaced. The only problem is that you can't buy just the spring.......for ~$10 you can replace all of it from Lowes or HomeDepot
My bathtub lever that allows the water to drain out of my tub, keeps closing, not allowing the water to keep flowing down the drain
