The printer is not initialising and giving an error code as service call error - 00010014. What should be done. We removed the cartridges and inserted again.
Same printer Epson 7800, Same service call error 0010014, same date, I have had it off for a few days waiting on an ink cartridge. Tried to start up today April 10th and I am locked out.
Hummm... could this be related to an embedded date set in production to stimulate service calls based on assembly date?
The 00010014 error code means that the Ink System Pressure Sensor reports that it is in low pressure. The error usually is caused by an Ink Cartridge that leaks pressure.
The 00010014 error code indicates that the Ink System Pressure Sensor reports low pressure. This error usually is caused by an Ink Cartridge that leaks pressure.
Try to replace the cartridges, look in your manual, there should be more information about this error and how to fix it.
00010014 - Ink System Pressurization Error (The Pressure Sensor does not indicate pressure)CClick HERE to view full detail on troubleshooting process.
EXPLANATION:
The error codes in the table below relate to a faulty ink cartridge or detection of the cartridge when installed in the printer. These errors only occur when an ink cartridge is changed. Whilst you may be unable to quickly identify which ink cartridge may be at fault, the steps below provide a process of elimination.
The problem is with the ink cartridge. remove the ink cartridge then insert it again... if this does not work, replace you ink cartridge. hope this help. Good day!
00010014 Pressurization error
Ink supply pressure incorrect
Explanation
The pressure system is determined to be leaking then this message appears and printer is stopped when detection of pressure origin sensor is incorrect at power on initialization or ink supply.
Solution
1. Replace supply pump assembly (including pressure origin sensor solenoid).
2. Check for disconnected air tube.
[email protected]
