SOURCE: video playback stutters is choppy
I had a problem similar to this and eventually traced it to the wrong mode setting on the DVD drive's transfer mode.
To check the setting, open Device Manager and then double click on the IDE controllers item. Double click on IDE channel (if there's more than one you'll need to check each one) and then select the Advanced Settings tab. On this tab should be up to two devices and each should show under "Current Transfer Mode" soemthing including the word "DMA".
If any device shows "PIO", then this is probably the problem.
If you Google "PIO versus DMA", one of the top results has a really good article on why this happens and how to force Windows to revert to DMA.
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer which can affect all of your computer
hope this helps
