Mintek MDP-1770 Portable DVD Player Logo
Posted on Apr 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WILL NOT PLAY A DISC
PUT THE DISC IN THE PLAYER, AFTER IT TRYS TO LOAD FOR A LONG PERIOD OF TIME, THE SCREEN READS OUT "NO DISC"
  • pepter7504 Apr 07, 2009
    after putting the disk in it just spins and ither no disk appears or it just loads for long periods of time
Anonymous
Level 3:
President:
  • Master 814 Answers
  • Posted on May 29, 2009
Anonymous
Master
Level 3:
President:
Answers
814
Questions
0
Helped
447830
Points
1474
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
2answers
My Samsung Blu-Ray player P1590 doesnt play regular DVD's. is this normal? Whenever I put a regular DVD it tries to load but it eventually posts a message on my TV screen saying "unable" to...
I have a Samsung BD-P1490. When I turn is on the display reads "Load." It never displays "No Disc", or trys to play a disc if one is present. I have never updated the firm ware. Any ideas?
Will not play disc.keeps saying disc error have tried several differnt discs.when disc in trys 2 load time after time then clunks clicks then it sez dic error.
Check for fingerprints or dirt on your DVD. Wipe it clean and try again. Also check for scratches. Try another DVD and see if your system reads it. If it does not try cleaning the drive laser lens with a CD lens cleaner available at places such as KMart or WalMart in the electronic section. If that still does not work chances are you laser on your drive is bad and needs replaced. It will need servicing.
1helpful
2answers
Dvd player will not play dvds
Motor was not working. Disposed of old player and bought another dvd player
When I put a dvd in it try's to load and then it reads on the screen "no disc" and It won't play my player is only 5 months old.
Well, first I have to ask if it does load? If it does, and is not reading the disc, it will say, "no disc". DVD's in general are very touchy and the Memorex is not a high quality brand. If only 5 months old, it should still be under warranty.
1helpful
Samsung DVD player when disc put in after trying to load it comes up with a message disc error on all discs
it can be two possibilities. 1)either the disk is faulty.check out in another player or drive and confirm whether the disk is properly working. 2)or the lens in the drive which reads the disk is either faulty or got dusty.in the electronics shop you get lens cleaning cd.insert that in your drive and play it.it will spin for a period of time and stop.then insert your dvd disk and check out if the same problem.then drive inner lens is faulty and needs replacement.
1helpful
2answers
Attempts to load then reads no disc
The problem is with the lens assembly. sometimes you may have to replace it(lens assembly) or optical pickup
1helpful
2answers
Player won't load any discs
I don't have a solution at this time. I have the same DVD player and mine stopped working this past weekend. It is doing the same thing as yours. I opened the case and loaded a disc and watched the mechanism. The disc won't spin. if you tap the disc it will start spinning and load and start playing. I thought I had fully fixed it. It will load most times but now the video and audio stutters as if the discs is spinning at varying rates.
Samsung 3650 dvd/vcr player loading problem
Sorry, no suggestion other than don't buy Samsung. That's my conclusion after owning the same model. It worked fine for a while, but now won't load any DVD... usually. Sometimes it will play one, but more often it won't. Mine tries to load ("Loading") for a long time, I hear the DVD spinning, then ultimately the screen displays "This disc cannot be played" or something to that effect.
1helpful
Won't play disc, reads no disc
Hi, well I see this type of thing in my Lab alla time unfortunately it sounds if ya DVD has gone faulty... an all too common occurrence these days.. the Laer seem to be very "Frail" You could try a cleaning Disk, but they seldom work.. but sometimes? all ya can do is replace it with another good DVD.. OR if thats not possible use any AV input and connect a remote DVD player that way.. a bit of a hassle, but it's a work around anyway.
Top Mintek Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
