Toshiba Satellite L645DS4040 Laptop Logo
Anonymous Posted on Aug 05, 2013
Keyboard keys wont type. used on screen keyboard to type this. any suggestions?
Anonymous
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 11 Answers
  • Posted on Aug 05, 2013
Anonymous
Contributor
Level 1:
New Friend:
Night Owl:
Answers
11
Questions
Helped
1124
Points
45
You might have "sticky keys" so try this:
When sticky keys are enabled, users can access functions that require pressing multiple modifier keys such as "Ctrl," "Alt" and "Shift" at once by pressing one button at a time. If sticky keys are enabled, it is possible to accidentally turn them on at an unwanted time. After turning off the sticky keys, disable the feature to prevent them from accidentally turning on again.
    • Press the "Shift" button five times in a row to turn off sticky keys.
    • Open the "Start" menu and then click "Control Panel."
    • Click "Ease of Access Center" from within the Control Panel window.
    • Click "Make The Keyboard Easier To Use" from within the Ease of Access Center window.
    • Remove the check-mark beside "Turn On Sticky Keys" to prevent sticky keys from being accidentally turned on.
    • Click "Apply" to save your changes and then click "OK" to close the window.
Hope this helps. Good Luck!
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    1helpful
    Delete key not working
    Instead of relying on the physical keyboard to type and enter data, you can use On-Screen Keyboard. On-Screen Keyboard displays a visual keyboard with all the standard keys. You can select keys using the mouse or another pointing device, or you can use a single key or group of keys to cycle through the keys on the screen.
    To type without using the keyboard
    • Open On-Screen Keyboard by clicking the Start button clicking All Programs, clicking Accessories, clicking Ease of Access, and then clicking On-Screen Keyboard.
    or
    Type "osk" no quotes on run...
    Hope it will help you....
    My computer wont go to the sign in page
    Could be a hardware or software problem, not enough detail to tell, however..
    Before you try anything remove all external devices and see if anything changes. Sometimes external device drivers can prevent KB working.
    Is there an icon the bottom left corner of the login screen? If so select Type without a keyboard and an on-screen keyboard should appear. Use the trackpoint/pad (or mouse) to log in.
    Now check the keyboard to see which if any keys are working.
    Let us know how you get on
    Cannot use shift key + number for numbers 1 through 4 and 7 through nine.Cant make any symbols(at sign,exclamation sign).I tried reinstalling keyboard driver,choosing different language,so on and so...
    You might have a hardware issue with your laptop keyboard. You have at least 2 options:
    1) connect a "normal" USB keyboard to your laptop and use it, instead
    2) run the On-Screen Keyboard (osk.exe) and access the characters/keys you want from there
    Good Luck!
    2answers
    Im using my mom Dell latitude D600 PC Laptop and It was working good then all of sudden S key wont Stop typing itself Till we press "r or T" it making it hard when it pops up out the blue. it...
    It seems that your laptop keyboard is not working any more. you need to buy new keyboard for ur laptop or if you want to use usb keyboard then remove this keyboard's cable, connect your usb keyboard it will work.
    I cannot use the the keyboard to type in my password on a Dell inspron 1545. some of the keys work ,like the caps key,I tried an external keyboard but it didn't work.the mouse works ok. thanks Bob
    Hi, Can you try to use the OSK?.On-Screen-Keybaord? you can open it by going to Start/Orb > then all programs > Accessories > Accessibility > Onscreen keyboard. if the software works, i would suggest you call Dell and check the keyboard on the system. It could be defective already.
    thank you for using Fixya
    My uiop keys wont work, on my laptop keyboard.. I have replaced it many times, and now my uiop keys wont work -- typed on On Screen Keyboard
    you must have configured the settings incorrectly when you installed the OS.go back and repeat procedure choosing correct type of keyboard.
    keyboard configuration is a basic function of all operating systems
    I cant access my email because my key board wont let me type the adress everytime i press ctrl and ' it wont happen
    If you are not able to type the the address by the keyboard then you can use the "On screen" keyboard
    and finish your job.
    Please rate me if this solution works for you
    Thanks......Have a great time
    1helpful
    Mouse pad wont work after water spill
    not difficult..with right tools and patience..the touchpad is part of the upper assembly, and requires that the bottom be removed. When I do this, it takes around an hour.
    got backup?
    1helpful
    Keyboard wont work after battery change
    remove the batteries for 2 minutes. Try pressing the shift or ctrl button when typing. Could be they are soft-stuck.
    Top Toshiba Computers & Internet Experts
    ExpressFiX
    ExpressFiX
    k24674
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
