Olympus FE-210 Digital Camera Logo
Posted on Mar 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Flash stopped working
My cameras flash has recently stopped working. I haven't used the camera much in the 2 years I've had it so it certainly isn't worn out. Everything else on the camera works perfectly.
  • Anonymous May 21, 2009
    If the settings are reset and the flash still doesn't fire, is there another way to restore it, or do I just need to buy a new camera?
Anonymous
Level 3:
President:
  • Master 919 Answers
  • Posted on Mar 24, 2009
Anonymous
Master
Level 3:
President:
Answers
919
Questions
0
Helped
348067
Points
2397
Have you tried to reset the camera to its factory defaults to see if it is a setting that is causing the flash not to fire? To reset the camera go to the menu left arrow to reset - highlight yes and press ok. This will set the camera back to factory settings. See if the flash fires now. If it does then, good. If not, then it is a repair issue with the flash assembly internally in the camera.
Sigma EF-530 DG ST - not working, on test or camera all 6 LED lights displaying. Any thoughts?
I don’t usually play with flash that isn’t built in- I prefer natural light, but...if this were me I would: A) take very fine sandpaper and very lightly go one time over all contacts for the flash and camera. B) I would also see if my button batteries in my camera needed changing. As I remember they have something to do with recognizing lenses and flash attachments. C) I would also make sure the batteries in the flash, although changed, were making proper contact with the battery terminals and might also lightly sand those as well since the flash is little used.
My flash will not work
You directed this question at me, but unfortunately I'm unable to provide you with a "real" solution at this time. FixYa has informed me that by providing you with this "solution" your question will then be made visible to other experts; hopefully one of them will be able to provide you with a real solution.
It would also help if you could specify the make and model of your camera.
Thank you for using FixYa.
Dec 06, 2011 • Cameras
When I am trying to take a picture and press the button to so, I see an "err" and a battery (the batteries are new) message that will not allow me to do so. I have tried taking the battery out...
On these cameras, if you're using ANY of the auto modes (P, A, S on the dial), the lense must be set to the lowest aperture setting (the highest number). Check to make sure this is the case. If it isn't, that's most likely your issue.
If you're using a non-CPU lense, this camera can only be used on M(anual) mode on your dial. If you haven't changed lenses this isn't likely an issue. If however you're using a new (to you) lense, this is a possibility.
According to the manual, the only other possibility is that your attached flash isn't set to the proper setting when using "P" mode. In this mode, the attached flash MUST be a Nikon dedicated flash unit set to TTL mode, otherwise fEE flashes with a little lightning bolt symbol. If you're not using a flash specifically designed for this model, remove it and try again. If you are, cycle the mode button on the flash until it reads "TTL" on the flash's LCD panel.
The manual makes no mention of fEE (error) and the battery indicator blinking, so these are the only things I can suggest with the information given.
Recently my Canon camera stopped taking pictures. It will take a picture if the flash isn't needed or of you turn the flash off; however, if the flash is needed, the orange flash light will come on...
If your camera is under warranty bring it to the nearest Canon Agency to have it check and repair. Most of the time the problem is mechanical and only the qualified technician can fix it.
My Pentax Optio M90's Flash has stopped working.. it doesn't matter if I have selected the flash to be on or off it still won't work. Even when setting are set at auto it still won't work...
Hi kerritm,
This indicated that it's time you need to replace your flash , therefore you can get it done via a service center,
The camera's flash has a certain life and you can't expect it to be ok for many years together ,
In unfortunate cases , it stops working due to hard ware failure.
Therefore , Please get the flash replaced and you would be able to use it.
Hope this helps..:)
Problems with flash
In certain modes, the flash settings cannot be changed. Select a different mode.
I´ve opened the camera to clean it up
1. You shouldn't have opened it. 2. You probably shorted out the capacitor...lucky you didn't get burned. 3. You need repairs...bring lots of money.
1helpful
I fully charge the battery and recently it lasts just 2 days in the camera whether being used or not. the camera is just 5 months old. Would this be abattery or camera fault
Mine is over a year old. I typically need to charge it once a month if not in use and otherwise after about 800 shots without flash or 300 shots with flash.
Flash use "kills battery dead"
The most likely culprit is a several year old battery that is not accepting or holding a sufficient charge. Turning the camera on, and taking a non-flash photo may not tax the battery too much. However, when the flash is called for, the power demand may exceed the battery's ability to deliver enough juice. A new(er) battery is probably your best bet to resolve the problem.
External Flash can't fix
Its becoz that flash is not compitable with your camera. You should buy only flash that are compitable with your camera.
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
