20 Most Recent Canon PowerShot S50 Digital Camera Questions & Answers
0answers
0answers
0answers
3answers
Sliding Lens Door Problem -- Canon S50
I had the same problem with a S50, where the lens door would not operate properly and would not open enough to cause the camera to activate. I took it apart and found that there are two small gears that keep the door on track, one had split in half and jammed the mechanism. They were white plastic, perhaps nylon? I found another S50 on ebay with broken electronics but a working lens door and took parts from it to fix my system. Getting the tiny gear in place was tricky as there are several springs used to activate the camera on switch.
1/11/2012 12:21:05 AM • Canon PowerShot... • Answered on Jan 11, 2012
How do I get my
In the next link, check Selecting Print Setting : DPUG1-EN.pdf (page 14 and next)
Good luck (remember to rate this answer).
6/2/2011 3:29:28 AM • Canon PowerShot... • Answered on Jun 02, 2011
2answers
The lcd screen is broken,
They don't really repair it. They charge you more than $150 and send you a factory-refurbished replacement.
4/20/2011 10:48:57 AM • Canon PowerShot... • Answered on Apr 20, 2011
The screen just wont turn
Try to shoot a picture and download to pC. If it is ok then your lcd is bad. You need to replace it.
3/22/2011 6:31:44 AM • Canon PowerShot... • Answered on Mar 22, 2011
The screen wont work but
If the lens is open them the led screen is broke.Find a store that sells them and buy one put that one in the package and return it.
3/20/2011 2:29:40 PM • Canon PowerShot... • Answered on Mar 20, 2011
When I open the lens
From what I have seen the best two options for fixing this are to force it out... not to the point of breaking but try to guide it until it comes out the rest of the way. You can try using a plastic pry tool to try and force it out. I wouldn't recommend using metal screw drivers or anything like that. The other method I've seen is to disassemble the camera and reseat the lens properly. I think you'll get it with the first method but let me know how it works out either way.
3/8/2011 7:18:12 PM • Canon PowerShot... • Answered on Mar 08, 2011
How do I display the
The date stamp only works in the "Postcard" resolution. Press the "Func Set" button, scroll down to the bottom to select postcard resolution.
Once that is complete press the menu button. Select the "Camera" menu, then scroll down to the Date Time Stamp selection to turn it on.
Regards,
Jacob
3/4/2011 10:02:21 PM • Canon PowerShot... • Answered on Mar 04, 2011
The setting have all worn of the top of the
Where's your owner's manual? It has a diagram of the camera parts.
1/13/2011 11:39:40 PM • Canon PowerShot... • Answered on Jan 13, 2011
LCD MOnitor works only in the sitch assist
Here is a copy of the user manual:
http://gdlp01.c-wss.com/gds/5/0900001345/01/PSS50CUG-EN.pdf
On page 28, it discusses that you can switch the LCD display on or off (which saves battery life) by simply pressing the DISPLAY button. The display button cycles OFF, On - no info, On - info.
1/9/2011 6:55:05 PM • Canon PowerShot... • Answered on Jan 09, 2011
Looking for software to load
You can download Canon software from
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_g_series/powershot_s50#DriversAndSoftware
You might want to consider NOT connecting the camera to the computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
12/17/2010 6:52:54 PM • Canon PowerShot... • Answered on Dec 17, 2010
Sliding door is broken: can I get a replacement
Sorry to hear about the broken part on you camera!
The good news is that it can be replaced. You can contact your nearest Canon dealer to get more details on what it will cost and how long it will take.
The bad news is that it is probably not going to be worth the money. A general rule of thumb I live by is that if a repair costs 50% or more than the original purchase price, buy a new one.
There will always be a possibility for a repaired camera to break again so just get a new one to avoid disappointment.
Ultimately is is up to you to decide but please consider the above information.
Regards
11/30/2010 6:08:48 AM • Canon PowerShot... • Answered on Nov 30, 2010
I dropped it and now the lens won't retract; I
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
5/25/2010 6:14:07 PM • Canon PowerShot... • Answered on May 25, 2010
Canon PowerShot S50 Digital Camera Logo
50 questions posted
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
PowerShot Canon
  • PowerShot Canon
Most Popular Question
sliding door broken get replacement
  • Cameras
