When I go to serch the web my computer is s l o w bringing up web addresses and most of the time I get that stupid page that says this page can't be displayed contaqct your isp . I contacted the ISP they say it's my modem and it needs drivers. It will bring up pages with no problem some of the time but it has been getting worse latley I have iolo firewall and antivirus working
Check you windows networking and sharing center.
check your internet options folder check out the last folder called advance option, put a check mark in the proper boxs that apply to your needs.
check folder options
check problems and report
check device manage updates
for drivers
www.drivershq.com
delete internet provider and reinstall as new software in the control panel
other software that may help alot is called winpatrol can find it at www.winpatrol.com it is worth every dime you spend.
rod
HTTP Web-browser Access
Most HTML browsers can be used, though Internet Explorer 4.0 or Netscape 4.0 are recommended. IE 2.0 and Netscape 2.0 and their predecessors are not supported. The HTML interface can be used to access the LAN (or WAN) IP address or it can be used with FTP to upload and download files to and from the router.
To log on to the modem via HTML:
1 Bring up your favorite web browser.
2 Enter the Ethernet IP address of the router (10.0.0.1 or Speedstream) in the "Location" or "Address" area where you enter web page addresses.
3 Refer to "HTML Web Interface" on page 20.
Page 20:
HTML Web Interface
The HTML interface for the router first displays a page showing the current configuration of the router. The first page also provides links to the following functions:
Advanced Setup
Leads to a more detailed interface with several links that allow more in-depth configuration of functions available on the router. This interface provides the following links:
• Configuration Procedures
• Status and Statistics
• Command List
This is where the user manual ends. I would suggest clicking "Configuration Procedures" and find the section for configuring Network Address Translation (NAT).
In that section (if it exists), you'll want to provide the private IP address of the computer running the Telnet server and forward port 23 to this IP address.
If NAT capabilities do not exist, I would consider changing the router to Gateway mode (described in the user manual) and buying your own router to handle the NAT firewall.
Don't know my way around where do i go to find the things you mentioned?
