Purchased a new TV in November 2008 that has an internal HD tuner and says it's HD ready to receive the signal. The TV stations perform tests where you can check your TV. Our new TV (which is hooked up to an antenna) says it's not ready. What's wrong?
DJUD
Try going into the setup menu and make sure it is set to antenna then do a channel program. You don't need to wait for a test there are plenty of channels already there. Both digital and analog channels are still available so you will still a message that you are not receiving digital if you are putting it on an analog channel. The channel number has to have a dot(.) in it like 8.1, 24.1 If there is no dot you are on an analog channel
