20 Most Recent
Westinghouse Electric SK-26H730S 26 in. LCD TV Questions & Answers
Westinghouse 26h730s- menu flashes on screen for
Hello, there are two things you can do to stop this, one is to perform a factory reset. You can do this by going to the menu, go under the settings tab, and select the last option which is the reset option. Another this you can try is to do a power reset which is to unplug the unit from the back of the TV for atleast a minute. If this all fails than you are looking to change the main board. You can find price and availability for parts on your TV at
[email protected]. If you need further assistance or would like me to troubleshoot with you please email me at
[email protected]. Also please rate me if this information was helpful.
Pedestal stand
Www.shopjimmy.com they sell stands and universal stands
How do i get my westinghouse sk 26h730s monitor to work with my HP desktop computer with windows XP?
There should not be a driver required for this. As long as your HP desktop has a VGA video or HDMI video output, you can connect to the back panel of the TV from the video port of the PC. Then, on the remote, select the "PC" option for VGA input, or HDMI for the HDMI 1 or 2 input(s). If the PC only has DVI output, then it is important to know if the output is analog or digital. If it is digital (DVI-D or DVI-DD] then there is no available port on the TV to support it. Using a DVI-VGA adapter on a DVI digital output will not work as there must be a digital-to-analog conversion in order to work.
My tv wont turn on
The set will need servicing, there are several things that could cause this. The problem is that by the time you pay to have it diagnosed + parts, It may be cheaper to get a new set.
