Canon PIXMA  mini260 InkJet Photo Printer Logo
A
Anonymous Posted on Apr 20, 2013
Pixma mini260 printhead clogged - Canon PIXMA mini260 InkJet Photo Printer
I have a Canon mini 260 ink jet photo printer with error code B200
Canon Printer Error Code B200 may point to many different items, but it's essentially a problem with the overheating of the print head. Other than that, the issues usually have to do with the full waste ink tank, the full waste ink pad, and other parts of the printhead.
For the Canon Printer Error Code B200, Canon technicians recommend some generic solutions for this issue to users. This suggestion includes turning the printer off and turning it on. But we noticed some more comprehensive solutions for the solution involving dealing with the printer heads.
Easy Solutions that Fix Canon B200 Error
1.Turn OFF the printer
2.Unplug the printer from the power source.
3.Open the printer cover then reveal the ink cartridges.
4.Remove the printhead from the printer be careful.
Continue Reading - Canon Printer Error Code B200
What,s the problem
You will get help from the following link
http://www.helpowl.com/p/Canon/Mini260/Research/34521?search=mini260%20canon%20printer%20power%20cord
3helpful
2answers
I am getting error code B200 on my Canon Pixma MP 620 printer
B200 IS BAD PRINTHEAD. i TRIED TO CLEAN CLOGS BUT IN THE END THE FIX WILL BE TO (REPLACE PRINTHEAD) IF UNCLOGGING PRINTHEAD OF DRY INK DOES NOT WORK. YOU CAN UNCLOG BY USING A PRINTHEAD CLEAMING KIT, BUT IF THIS DOES NOT WORK REPLACE HEAD. EBAY WAS CHEAP FOR ME 25 BUCKS PRINTER IS WORKING AGAIN.
I get the message 6A00 on my Cannon mini260
It is a ome kind of jam in the purge unit. Open the cover and pull out the power cord, and now you can move the printhead to the left and out of your way. Use a flashlight and a folded paper towel and examine the parking ink pads where the printhead comes to rest. It is inside on the far right. You want to see if the wiper blades are stuck extended. The should be all the way back but sometimes they stick forward. Press on them gentley and see if they free up.
If they are back, press down softly on one or both of the black ink pads with the paper towel. Be careful not to get ink on your fingers and it won't come off very easy.
If the printhead won't come to the center, then its jammed into some part of the purge unit. Plug the power back in and turn the printer on. At the power on cycle starts, press gentley to the right and then release. IF that does not work, repeat the power on/off and try again but this time wiggile the head both left and right. You don't want to use any force, you are just trying to free it from the jam condition.
Please rate the answer if it helps you to solve the issue.
Thanks for contacting Fixya.
1helpful
Error code
Hi
This may work
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
My canon pixma mini260 will not print full image
Make sure the settings are on A4 not A5. In the printer settings
1helpful
Canon pixma ip3000inkjet printer
The printhead is clogged.
See the following guide:
Canon iP3000/4000/5000 Printhead Cleaning Guide
If it does not work, replace the printhead: Genuine Canon Print Heads
old marine
old marine
ZJ Limited
ZJ Limited
