It's an aftermarket cartridge. I'm sure it's installed correctly. I read the manual and tried various reboot tactics. Nothing solves the problem.
SOURCE: Toner light stays on!!!
Open the toner door, then press and hold the 'Go' button till all the lights are lite, this will reset your drum counter.....
SOURCE: Toner Light stays on after new cartridge installed
NEWER MODLES HAVE A CARTRIGE ESTIMATING PROGRAM THAT NEEDS RESET (you need to tell the printer that it has a new cartrige). SIMPLY....
1. OPEN THE FRONT COVER.
2. TURN OFF.
3. HOLD DOWN THE GO BUTTON AND TURN BACK ON.
4. ONCE ALL 3 LIGHTS ARE SOLID, LET GO OF THE BUTTON & PRESS IT 2 TIMES RIGHT AWAY.
5. ALL LIGHTS SHOULD GO SOLID AGAIN, WHEN THEY DO PRESS THE GO BUTTEN 5 TIMES IN A ROW.
THIS SHOULD RESET YOUR PRINTER AND LET IT KNOW IT HAS A NEW CARTRIGE (even if it doesn't)!
Open front cover and hit "Options" button, you should see a prompt to "Change Drum". Don't hit 1 for yes or 2 for no. hit the "Start" button and then put in the number 11. You should see the word "Accepted" in the window. Close front cover and you should be all set.
SOURCE: replaced toner cartridge and light stays on the printer will not
how do i set the toner reset lever on a brother hl 5250 printer
SOURCE: Brother HL-2040 toner light stays on
I found this and it worked great.
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Testimonial: "Thanks!"
