Kenmore fridge model 106.79172990. Both vents from freezer to fridge were frozen solid. Underneath freezer bottom there was also frozen ice. I was not getting air circulation and the fridge was not cold. I have defrosted the vents and removed the ice. Why did this happen? What can I do to prevent it from happening in the future?.
I hav e G.E. and the vents in freezer are frozen completely-how do i defrost them?
You most likely have a defrost problem.or a clogged drain.you need to check your defrost heater defrost timer and thermostat.if ice is formed over drain then you can unclog drain with hot water.you will see when it is unclogged,water will run down drain without running over into bottom of freezer.
It turned out to be a clogged drain. Unfortunately, I had no idea where the drain was located so that I could unclog it. So I called
in a repairman to fix it.
