Water in the carb
Usually theres a small bolt under float bowl of the carb. remove small bolt and remove lower bowl to empty out - careful not snag the float or let float drop to far, the needle valve is attached to the float. Once bowl is empty you replace the bowl- the gasket is rubber and the one around the small bolt is a thin brass washer all reusable. To make sure the bowl is back on right make sure the shallow end of the bowl is directly under the needle seat area so the bowl won't restrict the float movement
