20 Most Recent Seloc Mercury Outboard Engine Repair Manuals SEC-1416 1990-00 2.5-275 HP Questions & Answers
a lot of the temp sensors you add on can not be wired to the temp alarm sensor. you will need a little bracket that bolts onto the head and holds the sensor next to the head. I would put to in the middle of the head to get the best reading.
Seloc Mercury... | Answered on Oct 26, 2019
cylinder head bolt
first torque 19 nm , second 37 nm and 3rd 90degree
Seloc Mercury... | Answered on Oct 23, 2019
I believe that motor has 3 carbs and the one feeding the #3 plug could be running too rich. May need adjusting or rebuilding.
Seloc Mercury... | Answered on Aug 23, 2019
lack of fuel flow
not advance on ignition
blocked main jets
Seloc Mercury... | Answered on Nov 23, 2017
0.45L / 0.48Qt
10W30 FC-W
There is also a sticker on the spinstarter
Seloc Mercury... | Answered on Oct 01, 2017
Box clogged?
Seloc Mercury... | Answered on Sep 25, 2017
If the trigger is not working it will not fire.. the trigger is kinda like a set of points in an older engine...tells the ignition when to fire..
Seloc Mercury... | Answered on Jul 10, 2017
With the info provide, sounds like you still have a bad solenoid..
1. Take your battery to a battery shop and have the cold cranking amps checked.
Seloc Mercury... | Answered on Jun 13, 2017
https://www.marineengine.com/newparts/part_details.php?pnum=MER47-42038Q02
Go to boats.net - Mercury parts - search under hp/serial range - select 20hp 2 cylinder - it will be under the first selection 0A730007 and up.
Seloc Mercury... | Answered on Mar 15, 2016
when an engine stalls or looses power at high rpms , it is because there is a higher need for fuel to supply that requirement
fuel shortage can be from
blocked filters
low float levels in the carby/s
vent problem in the fuel tank/s
perished hoses letting in small quantities of air
the hoses failing intrenally and blocking off the fuel flow
pump problems from bad diaphragm or the rubber in the hose again blocking the main jets in the carby/s
another area to be checked is the ignition system being able to provide the spark at a higher rpms
this problem can be from failing condenser, ignition module or coil/s
Seloc Mercury... | Answered on Jun 27, 2015
water can get into the engine oil from several points
if the engine has a sump oil cooler hen the cooler coil wil be cracked or corroded at the seal points
more likely the housing behind the water pump has corrosion in it behind the impeller and water pressure is making it leak into the sump
Seloc Mercury... | Answered on May 19, 2015
Seloc Mercury Outboard Engine Repair Manuals SEC-1416 1990-00 2.5-275 HP Logo
Popular Tags
96 questions posted
Top Seloc Boating Experts
Marvin
Marvin
Bill Boyd
Dariusz Zalewski
Dariusz Zalewski
Are you a Seloc Boating Expert? Answer questions, earn points and help others
View Most Popular
Seloc Boating
  • Seloc Boating
Most Popular Question
won t 1988 200 hp ob motor rev above
  • Boating
