I tried to reformat my laptop and I am getting error 320 and 350 when 95%finished.
Hello again,
Sounds to me that the software you are using is corrupt and if that is the case the only solution is to rebuild the OS by using a CD. This isn't uncommon, if their is a bad sector on the Hard Drive this can cause the software to error and become corrupt. A full reformat and installation is the only solution if the software is corrupt.
Hope that helps,
ArmyMason
I would ask around to see if a friend has a disk or you could contact the manufacturer to purchase a disk.
Thanks,
ArmyMason
Can you give me an update as to what you have done or has my help explained enough to you as to what you should do? I hope you understand their is going to be no work around in getting the soft version of the restore disk to work. You need to either contact the manufacturer to order CD's or find a friend who has a disk that will work for you. If you are satisfied with my response could you please rate my help. Thank you, and sorry for your luck.
ArmyMason
Did anyone come up with a solution? I'm getting the same error and I AM using the recovery disks from Sony.
It will reformat the hard drive, reinstall the software and get almost done... then error 320 or 330.
I thought I read somewhere that it was a optical drive issue so I used a USB optical drive with the same results.
Anyone?
Thanks.
A persistent operating system error on your Dell Inspiron 1525 laptop requires more than just a system restore as there is a problem with a driver that a system restore cannot correct.
A full factory reset of the laptop wipes the hard drive clear of all data including existing driver settings and programs and installs the original operating system back to the hard drive.
Once cleared, previous computer files and programs are non-recoverable.
Press "Power" on the Inspiron 1525, and continuously press "F8" on the keyboard when the Dell logo appears on the laptop's screen.
Press the down arrow to highlight "Repair Your Computer," and press "Enter" to select the highlighted onscreen option.
Click your preferred keyboard layout, and click "Next" to continue with the laptop's restoration process.
Type "administrator" in the username field, click "OK" and click "Dell Factory Tools."
Click "Dell Factory Image Restore," and click "Next." Click the checkbox next to the hard drive reformat confirmation, and click "Next."
Click "Finish" to reboot the OS after the restore process finishes, which can take up to 10 minutes.
Hope this helps.
I am reformatting from f10 has there is no cd it is built into program....I am not getting the blue screen...now window boot manager window comes up and when I pick vista it goes back to same error
I don't have a disk
Hi June,
Could you please be more specific to the error. Are you getting a Blue Screen of Death? How are you reformatting your laptop? CD or Floppy. Also need to know what are you formatting to NTFS or FAT32?
Thanks,
ArmyMason
